Pocket GPS World :: View topic - SPEED CAMERA SOFTWARE FOR V 5.420
tiger1
PostPosted: Fri Jan 20, 2006 12:14 am    Post subject: SPEED CAMERA SOFTWARE FOR V 5.420 Reply with quote
Hi There
Can anyone Help me?
I'm looking for Camera Software (or is it called POI Addons) Confused
I have a Tom Tom Go 700 and have just recently downloaded the newer version software... 5.420
It seems that the one on here is not compatible with this version. Is there any that is? If so where will I find it? Sad
Please be gentle! Not too technical please. Just bought the sat nav and Its my first time! Embarassed
Many Thanks Smile
Privateer
PostPosted: Fri Jan 20, 2006 12:30 am    Post subject: Reply with quote
Hi tiger1,
Welcome to the forum! Thumbs Up
The use of our POI Capture software with TomTom v5.420 has been discussed in several different threads.
Unfortunately, there will be no version of POI Capture software that will
work with TomTom v5.420. This is down to TomTom, as the 5.420 update is not suitable for TomTom GO devices running applications based on the TomTom SDK (Software Development Kit). The SDK uses application versions 5.202 or 5.203. POI Capture is an application that is based on the TomTom SDK. This is also true for every other application based on the TomTom SDK.
Please see the following for further explanation:
http://www.tomtom.com/support/index.php?Language=1&FID=1750
However if you wish to use our camera database then there are some guides that should be read (in the following order):
Arrow The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
Arrow How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
Arrow How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
Arrow The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Robert.
Garmin Camper 770 LMT-D
tiger1
PostPosted: Fri Jan 20, 2006 1:15 am    Post subject: Reply with quote
Hi Robert
Thanks for the reply, not sure I quite understand all that just yet... Confused
Like you said... need to sit with a cuppa to get me 'ed round that little lot!!
Best look when I wake up refreshed..me thinks
Cheers! for the info.. im sure i'll be back soon..screaming for help! no doubt teehee
Thanks Again
Julie
Ps Is there a charge for any of this software?
PostPosted: Fri Jan 20, 2006 3:01 am    Post subject: Reply with quote
Welcome to the forum Tiger Smile
To clarify further:
The speed camera "software" is not software at all, just a database of locations in TomTom's POI format. It is a collection of files and picture icons that you download from this site (for free this month, but scandalously for £2 next month). It will work on ANY version of the TomTom's firmware.
The "Capture" application is a way of simplifying the recording of new cameras (although you can still do it manually). It is that application which won't work on firmware other than v5.202.
