Pocket GPS World :: View topic - Safety Cameras not working
daps
PostPosted: Sun Jan 15, 2006 5:09 pm    Post subject: Safety Cameras not working Reply with quote
Help please... Since upgrading to CP6 I cannot get the speed camera's to work. Everything else announces OK, Garages, hospitals etc but no cams.
I did the pocket PC6 D/L from here...
http://tinyurl.com/awy4n
I still cannot get it to work. Any ideas please.
Alan
Garmin 2569
alix776
PostPosted: Sun Jan 15, 2006 5:58 pm    Post subject: Reply with quote
have you set it to announce cameras it should say saftey camera ahead
device Lumia 950 xl
iankb
PostPosted: Sun Jan 15, 2006 6:02 pm    Post subject: Reply with quote
  1. Download the latest zipfile release from this site, not the ALK site.
  2. Look in the "\single file version\ov2 bmp files" directory for the .OV2 and .BMP files, and rename them to "Speed Cameras.*".
  3. Use ActiveSync to copy the two files to the "\Save" directory on your PDA.
  4. Restart CP6 and wait a couple of minutes for the files to be imported and deleted. This is a one-off wait.
  5. Go into POI Alert settings and make sure that "Custom\Speed Cameras" is ticked.
  6. On your desktop PC, copy the same files into the "\Program Files\CoPilot\PocketPC6\EU\Save" directory, and restart the desktop program.
NB: If you import the files with more than one name, you will have to delete all of the custom POI's first, by deleting all of the "aopoi.*" files from the "\Save" directories.
Ian
iPaq 2210
Globalsat BT-338
Seidio G2500 Amplified Vent Mount
CoPilot 6, GPS Tuner 4.2, Navio 3.01
BMW 330ci Sport
alix776
PostPosted: Sun Jan 15, 2006 6:26 pm    Post subject: Reply with quote
or the really easy way if to just copy the ov2 files direct from the camera database file to the save folder on the sd card
device Lumia 950 xl
daps
PostPosted: Sun Jan 15, 2006 7:47 pm    Post subject: Reply with quote
Thanks All. I think I have done it correct as per above. I'm not the most
technical minded doing these things.
Is there a way to know if it will work without having to do a journey and approach a camera.
Regards
Alan
Garmin 2569
iankb
PostPosted: Sun Jan 15, 2006 7:54 pm    Post subject: Reply with quote
  1. Go into GPS settings and switch off the live GPS.
  2. Open an existing GPS track file for a day where the first trip passed cameras, and you know what the destination was.
  3. Set up a trip with that destination.
  4. Go back into GPS settings and start the track playback.
  5. Close the GPS settings and watch the track playback at a speed that you can set in GPS settings.
Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport
daps
PostPosted: Sun Jan 15, 2006 9:06 pm    Post subject: Reply with quote
Thanks for the prompt reply Ian. Another query... When I go into Open GPS track then into Co-Pilot_UK all I get for the track name is Co-Pilot_UK_Sample.gps and nothing with old trips. Any ideas.
Garmin 2569
iankb
PostPosted: Mon Jan 16, 2006 2:56 pm    Post subject: Reply with quote
If you select "All Folders" in the open dialog, you should see one per day. I think the actual folder is "/my documents/gpstracks" on your card.
Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport
daps
PostPosted: Tue Jan 17, 2006 4:46 pm    Post subject: Reply with quote
Eventually found it and works a treat.. Confirmed this afternoon on my short trip out. Thanks again.
Alan
Garmin 2569
22.062 (12 Jun 24)
