Pocket GPS World :: View topic - Can tomtom 5 be configured to use other receivers
stevo24
PostPosted: Sat Jan 14, 2006 6:43 pm    Post subject: Can tomtom 5 be configured to use other receivers Reply with quote
Hello Everyone
I have a T-Mobile SDA and tomtom5 mobile. My GPS reciever, a copilot D1598, is picked up by my SDA and pairs successfully. But when i go into tomtom it states that there is no gps device.
If I then go into the preferences and set it as other gps rather then tomtom i still get the same problem. I get a message from tomtom stating please pair devices but they already are.
Does anyone have any suggests.
Thanks for help in advance
PostPosted: Sat Jan 14, 2006 7:48 pm    Post subject: Reply with quote
Once the GPS unit is connected to the phone via BT go to GPS setup within TomTom and select the Other wired NMEA device , then the correct Baud speed for your unit (read the suppliers info for this) then on the last page select the bluetooth com port - its the out going one you need (tip - put the device into landscape mode first to be able to see the port numbers - its just easier this way) then take it outside and wait for a sync - if the blue/ yellow disk isn't spinning (top RH) then you have a problem with the settings, so try the other BT connection within TT - Mike
alix776
PostPosted: Sat Jan 14, 2006 7:50 pm    Post subject: Reply with quote
youll need to set an out going post in the bluetooth settings set an ot going port to com 6
device Lumia 950 xl
stevo24
PostPosted: Sat Jan 14, 2006 8:16 pm    Post subject: Reply with quote
Thaks lads, ill have to give this a go, gone and left me receiver at work
so will report back
stevo24
PostPosted: Sat Jan 14, 2006 8:43 pm    Post subject: Reply with quote
Hello
I have just checked within my tomtom gps config and i dont have Other wired NMEA device listed. I only have the tomtom device or other gps device.
Should this matter??
PostPosted: Sat Jan 14, 2006 8:51 pm    Post subject: Reply with quote
You should have a page that says "Other Cable NMEA GPS" use this - I know its a BT unit but go through what I said earlier in terms of configuration and it should work - Mike
stevo24
PostPosted: Sat Jan 14, 2006 9:24 pm    Post subject: Reply with quote
I dont have that option, i only have the 2 options mentioned
