shove2001 Occasional Visitor
Posted: Tue Nov 08, 2005 10:59 am Post subject: BT prob with BT-308 |
I've lost connection to my BT-308. The Blue light flashes once when you turn the unit on, then nothing. All other lights appear ok.
With no BT I can't do anything. Does anyone have any thoughts on this?
Mark |
Alessandro Occasional Visitor
Posted: Fri Nov 25, 2005 2:24 am Post subject: |
Hello, I have the same problem from this evening. Only an blibk of the bluetooth status led and then enough.
What can we make? |
crazybones Occasional Visitor
![](modules/Forums/images/avatars/500087c8406fce19a2919.jpg)
Posted: Mon Nov 28, 2005 9:57 pm Post subject: |
I've got the same problem suddenly with my BT308. Have you guys found a cure yet? |
DTech Occasional Visitor
Posted: Tue Nov 29, 2005 6:20 pm Post subject: |
Your BT-308 Unit is Faulty.
you need to return it to your dealer for repair.
David |
EasyD2 Regular Visitor
![](modules/Forums/images/avatars/1657901726438c327304bf8.gif)
Posted: Wed Nov 30, 2005 12:25 pm Post subject: |
Where did you buy your BT-308. You should have a warranty with your reseller. _________________ www.easydevices.co.uk
Tel: 0871 7000 156
Globalsat UK Distributor |
Posted: Wed Nov 30, 2005 9:21 pm Post subject: |
Sean - thanks for the reply. Unfortunately, my BT308 is over 12 months old and hence out of warranty. I'm guessing that the cost of repair & shipping will mean that it's not economic to repair. |
Posted: Thu Dec 01, 2005 11:38 am Post subject: |
Hi crazybones.
Even if your GPS receiver is out of warranty we can still have it repaired for you if you wish. It may not cost as much as you think and it will certainly be cheaper than buying a new receiver. Give us a call on 0871 7000 156 and we'll get something sorted for you. _________________ www.easydevices.co.uk
Tel: 0871 7000 156
miner3003 Occasional Visitor
Posted: Thu Jan 12, 2006 10:44 pm Post subject: bt 308 |
Can't seem to pair my bt 308 with a Ipaq 3970
what is the passkey code for the bt 308?
i think i booted my box and sheet out!! seem to remember a number being used i think??
Saying that it will pair with the Ipaq if i use memory map!!
Odd! is there a pairing post i could refer too? i have loked around the site but there is a mass of info up here.
cheers guys |
Posted: Fri Jan 13, 2006 1:17 pm Post subject: |
Your passkey should be 2003 _________________ www.easydevices.co.uk
Tel: 0871 7000 156
Posted: Tue Jan 17, 2006 12:43 am Post subject: |
EasyD2 wrote: | Your passkey should be 2003 |
Hey --- You da Man!
That worked superbly, just need TT5 to find it and i should be away
Cheers |
