Pocket GPS World :: View topic - Tomtom300/Rider/poi voice
pgchimp
PostPosted: Thu Jan 12, 2006 11:33 am    Post subject: Tomtom300/Rider/poi voice Reply with quote
Hello
I have been using my Tomtom 300 for the last 6 months with no problems, it was version 5.2?? and accepted speed camera alerts/Real voice camera warnings, New splash screens etc In fact no problems with anything
Last week i purchased a Tomtom Rider for the bike with a version # 5.410 which i have updated now to 5.420 thinking i was being clever
So here lies the problem, the Real camera voice warnings do not work, and having read loads and loads of threads on this subject i know why.
I can get garbage speech, or short mumblings like GATSO 30, but i want what i have on the 300 and that is
GATSO AHEAD SPEED LIMIT 30 MILES PER HOUR
MOBILE CAMERA AHEAD SPEED LIMIT 40 MILES PER HOUR
ETC ETC ETC
So i tried using the Card from my Tomtom300 in the Rider, No joy just freezes every time and needs a reset
Went back to version 5.410 on the Rider, no joy Real camera warnings still dont work even using the correct version # data chk file
I want the Rider the same as the 300 set up, so would it work if i installed version # 5.2?? on the Rider, ie went backwards and not forwards, I am not bothered about loosing all the extra that version 5.420 brings i just want speed camera warnings as on my 300 IE
GATSO AHEAD SPEED LIMIT 40 Miles per hour
So will i do any damage to the Rider by doing this backwards version upgrade, as i have loads of SD cards so backups are not a worry
Finally i note that the SD card memory on the 300 is about 118 meg but the Rider SD card is only 98.6 meg, why is this any ideas please
Hope you can help, sorry post so long winded
Alan
JLee
PostPosted: Thu Jan 12, 2006 12:31 pm    Post subject: Reply with quote
I'm using real voice warnings on a TTG500 running 5.42 with no problem. I used POIExtend from Ray Flan's site.
http://www.tomtomsatnav.info/poiw.html
pgchimp
PostPosted: Thu Jan 12, 2006 2:13 pm    Post subject: Reply with quote
Hi Jlee
Just been to Ray's site and took the trouble to set it all up, however unless i am missing something it is not what i want
It still gives out all the Bell/whistles/horn sonds etc and NOT voice spoken commands as i have on the 300 using SDK software
so am i missing a link here or is that all the site does
Any replies appreciated especially whether i can use a backward version on the Rider to achieve what i need
regards Alan
Sir_Fallot
PostPosted: Thu Jan 12, 2006 2:26 pm    Post subject: Reply with quote
pgchimp wrote:
Hi Jlee
regards Alan
SDK software does not work on the latest firmware update.
You need to download the appropriate file from the list on this page and follow the instructions to replace the bells and whistles with voices.
http://www.tomtomsatnav.info/realvoice.html
pgchimp
PostPosted: Thu Jan 12, 2006 3:34 pm    Post subject: Reply with quote
Hello Sir_fallot
visited that site before on several occasions and after downloading the two female and one male file over a priod of days alll they produce is the Bells and Whistles
I am installing correctly as have done so many times in the past and as i previously stated i have had the voice prompts working IN A FASHION ie not intellegable
I dont want to give up but am comming very close
regards Alan
berkeley384
PostPosted: Thu Jan 12, 2006 3:47 pm    Post subject: Reply with quote
which tool are using for POI extend ?
There are two , use the one for older software and it will not work
berkeley384
PostPosted: Thu Jan 12, 2006 3:55 pm    Post subject: Reply with quote
from a previous post ....
All sorted thanks to Rayflan
Tom Tom One users will need V5.420 and will need to use POI extended warnings 1.0d from this link ...
http://www.tomtomsatnav.info/poiextendgo5_42.zip
Sorry if this is a repeat of info already given
And once youve done it acouple of times it becomes super easy !!
Thanks again Rayflan
If your using the POI Extend software you used for your TT300 Pre V5.42 this should be version 1.0a I used this and it failed to work correctly
pgchimp
PostPosted: Thu Jan 12, 2006 3:57 pm    Post subject: Reply with quote
Berekely
could you please explain your answer, i do not understand
"What tool are you using for poi extend"
I am just downloading the appropiate data.chk file to the desk top renaming it from its original name to data.chk then replacing the one on the SD card with the new renamed one off the desktop.and then going to manage poi etc and doing the deeds to change from bleeps to voice
sometimes they half work and i get voice garbage, other times all i get is the bells and whistles
Regards Alan
pgchimp
PostPosted: Thu Jan 12, 2006 4:02 pm    Post subject: Reply with quote
Berekely
i understand now, when using Rays software i have been using
POIW Version 1.0d tested for use with TTGO software version 5.42
hope this helps you to assist
Alan
berkeley384
Another Thought , sorry about this but I cant edit my posts and Im supposed to be working here ... DOH
You havent said whether your extracting your TTN and creating your own POI data.chk file using the POI extend tool or if youve extracted your TTN and are using a pre made data.chk file from Rays website
berkeley384
PostPosted: Thu Jan 12, 2006 4:05 pm    Post subject: Reply with quote
OK so your using a pre made data.chk file, have you extracted your TTN and copied it into the Root folder of the SD card
pgchimp
PostPosted: Thu Jan 12, 2006 4:09 pm    Post subject: Reply with quote
Berekely
thanks for sticking with it, i have done both methods using RAYS site tried the 3 pre made data.chk files and also the one using the POI extended tool
I have also tried the pre made data.chk file off this site and one downloaded and bought on e bay all with the same results
Regards
berkeley384
PostPosted: Thu Jan 12, 2006 4:13 pm    Post subject: Reply with quote
and you have extracted your TTN from your TTsystem file using the extract_ttn.exe program ?
berkeley384
PostPosted: Thu Jan 12, 2006 4:24 pm    Post subject: Reply with quote
If you have extractted the ttn and dropped it along with your data.chk file in to the root dir of the SD card and it doesnt work , I would try going back to your previous version on 5.410 and re downloading the 5.420 update and re installing as at this point it sounds like youve done it all spot on
pgchimp
PostPosted: Thu Jan 12, 2006 4:29 pm    Post subject: Reply with quote
Berekeley
I am going to do just that, format the card and re start all over again just in case something has gone astray
i will call it a day for now while i try out a few things as you suggested, watch this post as i will let you know how i get on
Thanks for now
Alan
