A636 Occasional Visitor
Joined: Jan 09, 2006 Posts: 5 Location: Sydney, Australia
Posted: Wed Jan 11, 2006 3:38 am Post subject: CoPilot v6 Night Mode adjustable? |
The Night Mode function didn't change until after 9pm.
Only used it once @night.
I'm assuming it works off the clock? UTC?
Does anybody know if the NightMode start time can be adjusted? _________________ 8O A636
ASUS Mypal A636 GPS PDA: ROM v03.0547.00
Windows Mobile v5.1.70 (build:14402.1.1.0)
SiRF III chip on-board
Copilot Live v6.0.0.41 |
kartracer Frequent Visitor
Joined: 26/03/2003 20:15:33 Posts: 502 Location: United Kingdom
Posted: Wed Jan 11, 2006 10:38 am Post subject: |
It works as you thought, and I don't think you can adjust it. You can however switch between day and night modes manually if you use Left on the Directional Pad to toggle them. _________________ Kam |
Paul-m Regular Visitor
Posted: Wed Jan 11, 2006 12:41 pm Post subject: |
My night mode kicks in at 5pm. The only thought is if you have your ppc set to the right timezone and region. Apparently CP6 looks at these settings for some things. _________________ Wife 3 kids.... unversity fees...:-(
oh... and a few PC's and gadgets ;-) |
BMWBiker Regular Visitor
Joined: Dec 28, 2004 Posts: 133 Location: Ambler, PA USA
Posted: Thu Jan 12, 2006 1:38 am Post subject: |
The one time I found my Night Mode on/off time to be mis-adjusted by a couple of hours, after some investigation I found that my iPaq had me on the "Visiting" clock, in a faraway time zone. Switching back to the "Home" clock in the Clock Settings page restored normal Night Mode times. Or correcting the timezone of the visitor clock is equally good.
The iPaq (and maybe other PDAs) offers the convenience of the Visitor clock with its own timezone, so you can quickly switch from Home to the Other place you often go to, and the clock will be correct for that mode.
So CoPilot correctly goes by the Home/Visitor setting you choose. In my case I had a bad timezone set for the Visitor mode.
Coincidentally (maybe) this problem only occurred once, while I was riding from east coast US to California, across 4 timezones. Could it be that CoPilot detected that I had changed timezones and put me into "Visitor" mode? I didn't do this myself, at least not on purpose.
I've had no problem since, and I too found that you can toggle the night mode with the 4-way button. _________________ Doug
CoPilot 6.0.1.24 (USA)
Compaq iPaq 3970, with PC2003
Navman sleeve (3400)
Blue Tooth GPS |
Posted: Thu Jan 12, 2006 8:09 am Post subject: |
Thanks for the Manual Toggle button tip.
I checked my visitors time, but it was ok.
That will do it for me at the moment.
cheers
A636 |
KenS Regular Visitor
Posted: Fri Jan 13, 2006 12:24 am Post subject: |
And the 4-way button adjusts the volume as well. Good find _________________ --Ken
HP iPAQ h2210 ROM 1.10.07 ENG
Windows CE 4.20
Sandisk Ultra II SD 512Mb
Haicom 303MMF and BT-401 slipper
Copilot Live 6.0.0.68 |
PONDEROUS Frequent Visitor
Joined: Aug 25, 2004 Posts: 634 Location: Lincolnshire, England
Posted: Mon Jan 16, 2006 5:04 pm Post subject: |
It seems to me this automatic daylight/night-time switch is a real white elephant. If it wasn't I don't think that a manual switch would have been provided as well.
I M O, the developers' time, and the PPC memory, used to achieve this automatic feature would have been better used on some missing essential features, such as a user-specified Favourites list. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Posted: Wed Jan 18, 2006 6:08 am Post subject: |
I think you're right Ponderous.
I may have inadvertently bumped the left button while adjusting the volume, as I was being blinded by the bright screen, and it just happened to be 9pm, and thought it was automatic?? doh! _________________ 8O A636
Posted: Wed Jan 18, 2006 10:25 am Post subject: |
In agreeing with me above, A636 wrote that his PPC was displaying daylight colours at 9pm. However, the point that I was trying to make was that the automatic facility would be unnecessary even if it worked. A couple of button presses, or screen taps in the case of TomTom, does the trick, and it is needed twice a day at most. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Posted: Wed Jan 18, 2006 11:11 am Post subject: |
I havent had a problem with night mode really. It changes autoomatically at 5pm.
However, what would be better would be the ability to change the map style as in Tomtom as i find the night mode in CP6 still a little on the bright side.
The only problem i have is that i have an iPaq HX4700 with a touch pad and i sometimes inadvertantly switch night mode on which disables the automatice night mode. _________________ Wife 3 kids.... unversity fees...:-(
