adamf Lifetime Member
Joined: Jul 31, 2004 Posts: 410 Location: wolverhampton
Posted: Mon Jul 04, 2005 5:27 pm Post subject: tomtom5 forgeting things |
tomtom keeps forgeting home favs and poi warnings any idea thanks  |
frank11 Occasional Visitor
Posted: Mon Jul 04, 2005 6:08 pm Post subject: |
check this thread here |
Posted: Mon Jul 04, 2005 8:02 pm Post subject: hhhelp |
sorry dont realy understand that thred i done the poi thing ages ago tt3poi any more help please im using xda2s with a clipon with it?? |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Tue Jul 05, 2005 6:44 am Post subject: |
It's a problem with the file called Great-Britain-Map.cfg and it has the Read Only attribute set. This means that you cannot write any changes to it.
If you Copy the file to the PC you can view the attributes by Right Clicking the file and Selecting Properties. Then UN-Tick the Read-Only option and OK out.
Copy the modified file from the PC back to TT5 and when asked if you want to Replace the file, Click Yes. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
GMC Occasional Visitor
Posted: Sat Jan 07, 2006 7:27 pm Post subject: |
Oldboy wrote: | It's a problem with the file called Great-Britain-Map.cfg and it has the Read Only attribute set. This means that you cannot write any changes to it.
Copy the modified file from the PC back to TT5 and when asked if you want to Replace the file, Click Yes. |
Oldboy,
Firstly I'm a newbie, so be gentle with me! I'm using TT5 on an ipaq 2210.
I found your post about the loss of favourites from TT5, having lost all of mine yesterday. I've copied the Great_Britain file containing maps to my PC via ActiveSync, unchecked read-only and then copied back onto the SD card, again via ActiveSync. However, after doing so (and it does take quite a long time) I then tried to run TomTom, only to be greeted with "No maps found!" Any idea where I'm going wrong? Am I copying the file from my pc correctly? I have simply copied the folder marked Great_Britain but should I have opened it and copied all of the files before pasting on to the SD card? Sorry if this a dumb question but.....
All suggestions, however simple, gratefully rec'd. Thanks
GMC |
Posted: Sat Jan 07, 2006 9:20 pm Post subject: |
The .cfg file is in the Map Folder. This is the only file you need to copy. You will need to be able to see file extensions to positivly identify the file.
You will have to delete the cfg file in the Map Folder as Windows might not let you over-write it.
To get over the 'No Maps Found' I believe the correct procedure is to do a soft reset. _________________ Richard
Posted: Sat Jan 07, 2006 9:43 pm Post subject: |
Thanks Richard, I'll give that a go. |
Filler Occasional Visitor
Joined: Nov 14, 2004 Posts: 37 Location: Stratford upon avon UK
Posted: Sun Jan 08, 2006 11:14 pm Post subject: |
my tt5 forgets all home and favourites, as wekk as speed cam alert settings, also hangs on poi capture, i found that it seems to be when i use Kingston 1gb SD card, problem not as prolific with kingston 512mb card, still happens though, and ok when using CF card.
ipaq 2210 and latest tt5 updates _________________ Nigel
Blackberry Storm
iphone 3gs
Kenwood 5520bt with garmin built in
TT wired GPS - Rikaline Bluetooth 6030 GPS - CF307 CF card GPS - 512mb sd card - sprite full updated, and tt3 , 3.07. 256mb CF card - Win XP SP2 upgrad |
PAUL-R-S Occasional Visitor
Posted: Mon Jan 09, 2006 12:41 am Post subject: |
i kept having this problem and found it was due to me removing sd card out of card reader with out closing window first. |
Mikeact Frequent Visitor
Joined: Nov 29, 2004 Posts: 303 Location: West Sussex
Posted: Mon Jan 09, 2006 1:16 am Post subject: |
And when you exit TT3 or 5, do make sure that it is closed before hitting another program. Also, be sure to exit TT when you have finished using it, ie when you get home. The PDA should not be powered off, BEFORE exiting TT, pretty important I am led to believe. |
Jon49 Occasional Visitor
Joined: Jan 26, 2005 Posts: 9 Location: South Leicestershire
Posted: Wed Jan 11, 2006 10:18 pm Post subject: |
I am losing favourites twice a week now and it's becoming frustrating. I've followed the above advice although my map appears to be called Great_Britain_plus-map.cfg [about 2.06KB in size]. Copied file to PC but it is not a read only so I can't uncheck that box and copy it back. thought I'd got the solution here, but still need help please.
Just checked the cfg file to see that it is on the SD card still, and it is dated today, now I'm really confused!!! |
Posted: Wed Jan 11, 2006 11:05 pm Post subject: |
Have a look at this thread. _________________ Richard
Posted: Fri Jan 13, 2006 6:16 pm Post subject: |
Thanks for that link
I need to check whwn I turn off then, but I always [or at least I thought I did] shut down the application prior to turning the Ipaq off. I do like the idea of saving favourites into POIs though, that seems to be a sensiible and more robust solution. Must try it. |
Posted: Mon Jan 23, 2006 8:15 pm Post subject: |
Just a foot note,
I save all my favourites as poi's when using the dreaded sd card, however, i have now run for 1 week on CF card, saving favourites, poi warnings, and checkpoit, guess what !! not a single data loss or glitch,
the sd cards have now been well and truly formatted for the digicam
nigel  _________________ Nigel
Blackberry Storm
iphone 3gs
Marty-Party Regular Visitor
Posted: Tue Jan 24, 2006 1:10 am Post subject: |
I have TT5 running OK on my XDA2i with a 128MB SD card. To enable storage of favourites etc I have write enabled the map file as detailed on this thread.
However, I still can't add or delete POIs on the move. Often I would like to add a new POI or even delete an old camera location. However, I always get an error.
Is the POI stuff held in another file which also needs to be write enabled?
Thanks |
