Pocket GPS World :: View topic - speed cameras
speed cameras
thehammer
PostPosted: Thu Jan 05, 2006 12:05 am    Post subject: speed cameras Reply with quote
hi just put speed cameras on my tomtom one. i put the speed files on so when i go past a camrea it bleeps and shows a round circle with the speed limit in it. should it show a camera and the speed limit? do i need to put the other files on [ie] the ov2 bmp. Embarassed Question
Privateer
PostPosted: Thu Jan 05, 2006 1:54 am    Post subject: Reply with quote
Hi thehammer,
There are some guides that should be read (in the following order):
Arrow The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
Arrow How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
Arrow How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
Arrow The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Robert.
Garmin Camper 770 LMT-D
jamsie81
PostPosted: Sat Jan 14, 2006 3:51 am    Post subject: Reply with quote
hi there the hammer,
i just put the camera database on my tom tom one and just to let you know mine does the same so i wouldnt worry. If you zoom out you can see what type of camera it is if that helps.
