mat_tickner Occasional Visitor
Posted: Thu Dec 29, 2005 12:33 pm Post subject: speed camera on tomtom one |
hi can you help
ive downloaded the poi files containing the speed camera
and installed them in the great britain map folder
but cant get them to work
i copied all the bmp images and all the other files and not just cut and paste the folder like it said
but i cant get the thing to work still
please help |
mossman Regular Visitor
Posted: Thu Dec 29, 2005 12:52 pm Post subject: |
Have you enabled the new categories of POI? |
berkeley384 Occasional Visitor
Posted: Thu Dec 29, 2005 12:53 pm Post subject: |
Hello
Ive just done this ....
Do you want just standard camera types i.e Gatso , Mobile , specs .... or Gatso 30 zone , 50 zone etc
If you want the first style open the folder call ov2 bmp files I believe there are 12 files , 6* ov2 and 6* bmp
Copy the all (cntrl A right click copy) and then drop them in to the great britain map folder
Once there all copied across - disconnect the Tom tom and start it up
You now need to enable you new Points of interest - to do this go to Change Preferences - Manage POI - Enable disable POI
Go through the list and put ticks next to your new catagories
Then - Go Change Preferences - Manage POI - Warn when near POI and you can set up warning beeps etc to alarm you of them
If you want the full list i.e Speed zones - Gatso 30 , 50 , 60 ,70 etc then DO NOT copy the files from the folder called "ov2 bmp files"
Open the folder called Speed Zoned from the Zip you downloaded and then open each sub folder i.e gatso specs and mobile and copy the ov2 and bmp files within them in to the great bitain map folder - Again DO NOT just copy the folders , copy the contents
Then enable as per the above and ad warning sounds etc
Hope this helps |
Posted: Thu Dec 29, 2005 1:03 pm Post subject: |
i downloaded and unziped the folder
inside the "go" folder there are now 2 new folders called
"poicapture" and
"SdkRegistry"
no Ov2 bmp |
Posted: Thu Dec 29, 2005 1:15 pm Post subject: |
ok downloaded the propper file
and i think ive got it sorted
thanks |
Posted: Thu Dec 29, 2005 3:03 pm Post subject: |
Glad it's sorted. |
