Pocket GPS World :: View topic - speed camera on tomtom one
mat_tickner
PostPosted: Thu Dec 29, 2005 12:33 pm    Post subject: speed camera on tomtom one Reply with quote
hi can you help
ive downloaded the poi files containing the speed camera
and installed them in the great britain map folder
but cant get them to work
i copied all the bmp images and all the other files and not just cut and paste the folder like it said
but i cant get the thing to work still
please help
mossman
PostPosted: Thu Dec 29, 2005 12:52 pm    Post subject: Reply with quote
Have you enabled the new categories of POI?
berkeley384
PostPosted: Thu Dec 29, 2005 12:53 pm    Post subject: Reply with quote
Hello
Ive just done this ....
Do you want just standard camera types i.e Gatso , Mobile , specs .... or Gatso 30 zone , 50 zone etc
If you want the first style open the folder call ov2 bmp files I believe there are 12 files , 6* ov2 and 6* bmp
Copy the all (cntrl A right click copy) and then drop them in to the great britain map folder
Once there all copied across - disconnect the Tom tom and start it up
You now need to enable you new Points of interest - to do this go to Change Preferences - Manage POI - Enable disable POI
Go through the list and put ticks next to your new catagories
Then - Go Change Preferences - Manage POI - Warn when near POI and you can set up warning beeps etc to alarm you of them
If you want the full list i.e Speed zones - Gatso 30 , 50 , 60 ,70 etc then DO NOT copy the files from the folder called "ov2 bmp files"
Open the folder called Speed Zoned from the Zip you downloaded and then open each sub folder i.e gatso specs and mobile and copy the ov2 and bmp files within them in to the great bitain map folder - Again DO NOT just copy the folders , copy the contents
Then enable as per the above and ad warning sounds etc
Hope this helps
mat_tickner
PostPosted: Thu Dec 29, 2005 1:03 pm    Post subject: Reply with quote
i downloaded and unziped the folder
inside the "go" folder there are now 2 new folders called
"poicapture" and
"SdkRegistry"
no Ov2 bmp
mat_tickner
PostPosted: Thu Dec 29, 2005 1:15 pm    Post subject: Reply with quote
ok downloaded the propper file
and i think ive got it sorted
thanks
mossman
PostPosted: Thu Dec 29, 2005 3:03 pm    Post subject: Reply with quote
Glad it's sorted. Smile
22.055 (29 May 24)
