Pocket GPS World :: View topic - Navigator software question
apollo
PostPosted: Wed Dec 28, 2005 12:00 am    Post subject: Navigator software question Reply with quote
Will the navigator sofware supplied with this http://www.aldi.co.uk/special_buys2/product_5318.html run on my Mio 168 or A201
PostPosted: Wed Dec 28, 2005 1:09 am    Post subject: Reply with quote
yes but you may run into registration issues since the software may already be registered for the machine it comes with.
apollo
PostPosted: Wed Dec 28, 2005 2:36 pm    Post subject: Reply with quote
Thanks m8 the reason I ask is because I bought the above device for my wife and have tried installing the software into my 168 and A201. On the 168 it will not install at all when I try to run the .exe file from the 168 it says its not a validPocket Pc application and when I run the cab file it says Medion Navigator was not succesfully installed (withih a few seconds of saying installing) Please run setup again.
On my A201 the .exe file runs but the screen flickers a few times and does nothing else.
When I run the cab file it installs fine but does not appear in the programs list and when I select it manually from the program folder, it comes up with the following error:
FAILED TO LOAD:
With another box stating:
The UCF-Path does not exist. Correct the path or set the resource to "-"
If i keep pressing the ok it then comes up with another box stating:
Could not load resource DLL.
DLL: \Storage Card\ Medion|langGer.dll
Error: 126
Are you sure it is compatible with these MIOs?
PostPosted: Wed Dec 28, 2005 3:39 pm    Post subject: Reply with quote
yes, hardware compatibility is most probably not the issue. You seem to be missing a few CABs from a multi-cab setup.
Try running the setup exe from the PC with the PDA connected via ActiveSync.
