Pocket GPS World :: View topic - Slow signal pick up TT5
Bity
PostPosted: Fri Dec 23, 2005 6:17 pm    Post subject: Slow signal pick up TT5 Reply with quote
Crying or Very sad How long should it take to start receiving a signal with my TTN5 linked to my Acer X50. It can take anything from 5 minutes (rarely) to over 50 minutes. Once it has picked up a signal it works like a dream. I presently use a mobile receiver linked by bluetooth, but I also have a hard wire arial but gave up on that because that also took forever to get a signal. Any ideas anyone?
PostPosted: Fri Dec 23, 2005 7:00 pm    Post subject: Reply with quote
Allow your receiver to get a fix BEFORE you start TTN. What you experience is very common with (unsupported) built in receivers, but can also happen with BT.
mikewhite75
PostPosted: Sun Dec 25, 2005 1:41 am    Post subject: Reply with quote
Hi There,
I've also same problem, just to be more clear, what do you mean
do i need to turn the antenna first before start or something else
thanks
PostPosted: Sun Dec 25, 2005 1:50 am    Post subject: Reply with quote
You need to wait until the GPS unit is seeing a signal, this is usually displayed on the LED segments fitted into the GPS unit itself, once this is signaling it has a signal then fire up the TomTom application - Happy Christmas Mike
mikewhite75
PostPosted: Sun Dec 25, 2005 2:45 am    Post subject: Reply with quote
thanks for your reply,
I never seen a green indicator on my mio 168, i bought it from http://www.globalpositioningsystems.co.uk/
they said it was a returned one but we checked all, it looks they didn;t check anything at all, i've a problem with my charger too i can not insert into pda
now just you light me up the gps indicator, really i'm fed up by them they told all lies
PostPosted: Sun Dec 25, 2005 5:39 pm    Post subject: Reply with quote
The Mio doesn't have an indicator. Just flip the antenna out and wait two to five minutes. You can use WinFast or another monitoring tool to understand if it has a fix yet.
mikewhite75
PostPosted: Sun Dec 25, 2005 6:16 pm    Post subject: Reply with quote
Aftere power indicator, i've another indicatoru near to that what is that
then i'm new to pda can you tell where can i download winfast
Mike
Windows Mobile 2003 + Mio 168 + Tom Tom 5.21 + POI Capture + POI Camera Installed
Bity
PostPosted: Tue Dec 27, 2005 11:04 am    Post subject: Reply with quote
Wink Thanks Ibendlin I will give it a go.
Dabhand16
PostPosted: Fri Dec 30, 2005 11:28 am    Post subject: Reply with quote
Don't forget that the power cord will only fit one way, and you must squeeze the two buttons on either side of the plug to insert/remove the cord.
Dabhand16
Bedfordshire
Mio 168 / Windows Pct PC 4.2 b14053 / Intel PXA255 / Kingston 512
TTN3 3.03 (427) / Sprite Premium 3.1.4 b2419 / CheckPOInt 3.2.0.0 / Digitools UK PostCode / GPSW Safety Camera Database
mikewhite75
PostPosted: Fri Dec 30, 2005 1:59 pm    Post subject: Reply with quote
Thanks for you reply, Yes i know i need to press the 2 sides of that, I've been using like this type of power cord long time
but this one is broken the silver small plate is out of handle, anyway i sent back to them let us see
Mike
