cantgetlost Frequent Visitor
Posted: Thu Dec 15, 2005 12:22 am Post subject: Aerial ? |
If using add on external Aerial with I3, does the external aerial work alone or does the in built aerial do split duties? |
RODTROTTER Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Thu Dec 15, 2005 2:06 am Post subject: |
it acts like a booster both work at the same time |
xander Occasional Visitor
Posted: Thu Dec 15, 2005 1:38 pm Post subject: |
Got mine off eBay - well worth getting - as I had a UV treated (Renault) windscreen and couldn't get a singel/lock-on with one. Did notice that rechargeable batteries got used up slightly faster though... |
NoLCD Occasional Visitor
Posted: Thu Dec 15, 2005 10:22 pm Post subject: |
Most GPS aerials are active and require, typically a 5V, supply so will unfortunately use more power. |
semaj Occasional Visitor
![](modules/Forums/images/avatars/gallery/gorilla_skull.jpg)
Posted: Sat Dec 24, 2005 6:53 pm Post subject: |
The antenna dont need to be mounted externally. Mine is in the rear window and works great .This is probably du to it not being treated or coated as was mentioned. |
