Pocket GPS World :: View topic - holux cr100
holux cr100
sexyali
PostPosted: Wed Dec 14, 2005 6:47 pm    Post subject: holux cr100 Reply with quote
i'm just got my cradle today and went for a drive too test it out... the only problem i'm having is it keeps loosing connection every 2 or 3 mins but aquires it again within 10 seconds, is there a way to fix this?
regards
jimbo_hippo
PostPosted: Thu Dec 15, 2005 12:25 pm    Post subject: Reply with quote
Ali,
You didn't mention what hardware you were using. However you might wanna take a look at a post I made a while ago. But bear in mind this was very Hardware specific. Also check under the connections in settings that you have incoming beams switched off. Let us know what hardware you're using and check this one out.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=28701
For what its worth, mine is rock solid and has been for months. I don't even think about it any more. Picks up sattelite quickly and keeps them so it certainly isn't a case of the hardware being poor.
Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim
sexyali
PostPosted: Thu Dec 15, 2005 6:20 pm    Post subject: Reply with quote
i've got the xda IIi running tomtom 5.0 on the coporate install i did the upg to tomtom 5.21 last night and it seems to be fine
the only problem now is getting the damn thing in the cradle - Laughing Out Loud
sexyali
PostPosted: Fri Dec 16, 2005 10:44 pm    Post subject: Reply with quote
still getting problems
should i contact the supplier or holux?
alix776
PostPosted: Fri Dec 16, 2005 10:59 pm    Post subject: Reply with quote
what problems are you get please
device Lumia 950 xl
sexyali
PostPosted: Sat Dec 17, 2005 1:34 am    Post subject: Reply with quote
when driving around the satnav looses connection every 2-3 mins for approx 10 sec's then aquires the signal again
alix776
PostPosted: Sat Dec 17, 2005 3:09 pm    Post subject: Reply with quote
have you left it a while to get a good first lock around 30 mins should be enough but you have to be stationary and and when your not useing it keep it pluged in to matain the internal battery
device Lumia 950 xl
jimbo_hippo
PostPosted: Sun Dec 18, 2005 1:08 pm    Post subject: Reply with quote
Ali
If you're stumped, call Holux and talk it through with them.
If I was you I would do a hard reset of your system and re-install stuff one by one but I'm comfortable doing this where you may or may not be. So the guys/gals at Holux will be able to help you. Great support there.
However, I do a fair bit of tech support and my best advice to anyone is to put the kettle on. Yep, thats right, make some tea. Even the most competent of techies arrive at the point where they can't see the wood for the trees. Take a step back, read all the documentation and follow a clear path of ellimination. Bear in mind that Sat signals can take a a while to pop up. These forums are full of people who have actually done something right but haven't waited long enough to see it happen! Its a personal bugbear of mine. The stepson is a total PC genius but sometimes he's going so damn fast he has no idea what he's done. Us 'oldies' are a tad more patient because we once had to wait for the tele to warm up :-)
Apologies if I'm patronising you but my intentions are good and I just want to see you get it working!
Tom Tom GO 720
Holux GPSslim
SatNavNews
PostPosted: Thu Dec 29, 2005 5:29 pm    Post subject: Reply with quote
I totally agree, it's always best to sit back, brew a cuppa and have a think about things, let nature takes its course and if it's still not working, call Tech Support.
Editor,
JM-HoluxUK
PostPosted: Wed Jan 04, 2006 11:20 am    Post subject: Reply with quote
Did the CR100 get an initial lock of more than 3 sats before you started your journey? If not sit tight for a couple of minutes before starting off to allow the 3D lock to be acquired.
Can I ask which dealer you purchased the CR100 from?
Julie
sexyali
PostPosted: Fri Jan 06, 2006 5:30 am    Post subject: Reply with quote
i purchased it from clove technology...
JM-HoluxUK
PostPosted: Fri Jan 06, 2006 10:38 am    Post subject: Reply with quote
I'm sure there is something about the TTN5 corporate install that needs something setting up on the phone side of the XDA2i to stop the PDA trying to grab the com port when it polls the network.
Can you give me a day or so and I'll come back to you.
Cheers,
Julie
