Pocket GPS World :: View topic - CP6 routing profiles
weirdfish
PostPosted: Wed Dec 14, 2005 6:16 pm    Post subject: CP6 routing profiles Reply with quote
I'm been playing around with the routing profile facility today but I can't seem to change anything. Confused I select advanced and edit (or create a new profile) and no matter what settings I change when I OK it, the profile has remained unchanged and as per default.
I have no doubt its something I'm doing wrong but the time has come to cry HELP Rolling Eyes
Robin2
PostPosted: Wed Dec 14, 2005 10:37 pm    Post subject: Reply with quote
I doubt if it's anything you are doing. There are a number of user adjustments which do not stick on my PDA
    Road speeds
    km/hour on map
    shortest
Robin
Satmap Active 10
weirdfish
PostPosted: Wed Dec 14, 2005 11:15 pm    Post subject: Reply with quote
Yeh that's pretty much what I'm having probs with. Rolling Eyes
CrashBiker
PostPosted: Thu Dec 15, 2005 12:39 am    Post subject: Reply with quote
I had exactly that problem then found my SD card write protect switch had been knocked so it was half way between locked & unlocked.
Moving fully back to unlocked I could then add new profiles.
Just a thought
Crash
weirdfish
PostPosted: Thu Dec 15, 2005 12:58 am    Post subject: Reply with quote
I already tried that Confused
Robin2
PostPosted: Thu Dec 15, 2005 1:29 am    Post subject: Reply with quote
That was what they suggested to me when I rang ALK support. But I have tried using a CF card and SD card, neither of which have write protect switches. And I can obviously write on them, because I loaded the software/maps to the cards using a card reader
Robin
Satmap Active 10
weirdfish
PostPosted: Thu Dec 15, 2005 9:55 am    Post subject: Reply with quote
Robin, have they said anything else? I'm going to try and ring them today.
I never had any major problems with CP5, however I upgraded for the increased functionality, most of which dont work!!!
Robin2
PostPosted: Thu Dec 15, 2005 4:33 pm    Post subject: Reply with quote
No, they promised somebody would get back to me, but nothing so far
Robin
Satmap Active 10
weirdfish
PostPosted: Thu Dec 15, 2005 4:46 pm    Post subject: Reply with quote
I've just spoke to them and they are now saying that it is a known issue and they are working on it Confused
H_O_D
PostPosted: Mon Feb 13, 2006 12:45 am    Post subject: Reply with quote
Out of interest, which version is this (go to the "About" page).
I had a (unknown) version from T-mobile that exhibited that very same problem. I ended up with five profiles ALL with the same (default) settings before discovering it was "a known bug".
I ended up having to return my handset and software to T-mobile (long story of extremely poor customer service) and now have the O2 variant on the imate K-JAM and version 6.0.0.68 of CoPilot which DOESN'T exhibit this fault.
FatOldSun
PostPosted: Tue Mar 07, 2006 12:21 am    Post subject: Reply with quote
I have a couple of problems with the profiles. I set up a couple of profiles for quickest and shortest routing, then I set one up using the slowest speeds possible to allow for cycling. However from then on, even if using the default profile, the ETA time was far too long! For example I wanted to drive to Oxford, I left at 8.15pm and I know it takes about 40 minutes, but the ETA was 11am the next day! As I was driving along the ETA was dropping by about a minute every second.
So I thought I'd delete the slow profile to fix it - then found no way to delete it! So I changed all the settings to fairly average speeds and now it seems to work OK. Anyone else experienced this problem where adding a profile seems to affect all the others?
Robin2
PostPosted: Tue Mar 07, 2006 2:34 pm    Post subject: Reply with quote
There is a known fault where ETA is calculated assuming a speed of 1 mph! Often uninstalling and reinstalling will fix this - it did so in my case and the fault has not reappeared for 3 months.
Robin
Satmap Active 10
Redhotorange
PostPosted: Wed Mar 22, 2006 5:19 pm    Post subject: Reply with quote
I reported the problem months ago to ALK. Last week they finally replied. The thought that this was caused by corrupted software on the SD card. They asked me to send my card to them so they could load the card up with "uncorrupt" software. I will find out if it will work when I get my card back.
They also told a new patch will be available on their website in 2-3 weeks which should resolve these issues. Let's waite and see.
orion_jb2001
PostPosted: Wed Oct 11, 2006 8:57 pm    Post subject: Reply with quote
I have the Australian version 6.0.4.98 and the speed glitch is still there. Does anyone know if it has been solved???? Very annoying trying to set profiles, with the program making its own descions!!!!
nivek22
PostPosted: Wed Oct 11, 2006 10:20 pm    Post subject: Reply with quote
I can't claim the credit for this, it was posted on this forum a while ago but I can't find the thread...
ETA = DISTANCE 1mph 60mph
\SD Card\COPILOT\SAVE. Using Activesync or a card reader check whether these files show up with a size of 0 bytes. If they are then you have the dreaded 1mph problem.
There is a specific sequence of commands which causes these files to be created empty but once fixed they appear to be fixed for good. This explains why some users have encountered the problem and others have not.
So now to the fix:
Start Copilot
Select Menu - Trip - Settings
Select Routing
Click Advanced
Select the Default profile
Click OK
Select Menu - Quit Copilot
Using Activesync or a Card Reader: Delete the empty usertrip.dat and userstop.dat in \SD Card\COPILOT\SAVE
Restart Copilot
Select Routing
Click Basic
Change the London Congestion Zone Warning (Check if unchecked or uncheck if checked as any change will force Copilot to recreate the files)
Click OK
Select Routing
Restore London Congestion Zone Warning (Back to your preferred value)
Click OK
Using Activesync or a card reader: Confirm that gpstrip.trp, usertrip.dat and userstop.dat have been created and are not empty.[color=blue
