Pocket GPS World :: View topic - TT One Power Adapter
adrianl
PostPosted: Tue Dec 13, 2005 1:59 pm    Post subject: TT One Power Adapter Reply with quote
Getting a PSP mains adapter for the TT One seems like best value solution for charging at home, but is the plug at the end of the PSP charger same size as the one for the TomTom?
Asking because was in Maplin yesterday browsing chargers and even looking at all the different size tips I didn't find one which seemed a good fit in the TomTom, short of ripping open packets! The one with a hollow central pin wide enough for the TomTom were too wide to fit the aperture for adapter tip.
Am a little wary of using a universal switch supply anyway just in case it gets knwocked from 4.5V position and fries the One. Also considered mains cigar lighter socket adapter but then sod's law is I'd forget to take the car charger lead with me when I needed it back in car!
In short does PSP adapter tip (car or mains) fit?
Unplugged
PostPosted: Tue Dec 13, 2005 3:09 pm    Post subject: Reply with quote
Too low a voltage shouldent hurt the One its anything above say the 6ish mark that will start the cooking procedure.
Car Power Supplys are between 11-14v depending on the alternator and what you have running Although the one has a Voltage Regulator in the charger iirr there is a error of +- up to a set level depending on the input voltage someone will hepefully confirm this :p
anyway a good mate of mine charges his 500 up on a universal adator at 6v and last time i looked it seemed to be fine if not his driving Laughing
You can always find an adaptor with the correct pin and cut the end of an adaptor that does fit as long as you get the wires the right way round theres normally only two.
ChocolateTelevision
PostPosted: Wed Dec 14, 2005 9:05 pm    Post subject: Reply with quote
This one works fine here:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=5840046716&rd=1&sspagename=STRK%3AMESE%3AIT&rd=1
:D
Flashyphotos
PostPosted: Wed Dec 14, 2005 9:33 pm    Post subject: Reply with quote
I have been using a PSP Power Supply for a while with the One, and it works like a dream,
There are some very good deals on secondary market PSP supplies so it makes a cost effective solution
Flashyphotos
PostPosted: Wed Dec 14, 2005 9:34 pm    Post subject: Reply with quote
Forgot to add
Yes the PSP supply is exactly the same tip as the TTOne
adrianl
PostPosted: Thu Dec 15, 2005 1:25 am    Post subject: Reply with quote
Thanks for the tip (no pun intended!).
Will seek out a cheap psp charger and take advantage of the burgeoning mass amrket in PSP accessories!
Adrian
ftodude
PostPosted: Thu Dec 15, 2005 12:07 pm    Post subject: Reply with quote
I hunted around my stash of psu's and found that the psu from my old Cassiopeia PDA to be an exact match! output DC 5V 2A
owls
PostPosted: Thu Dec 15, 2005 5:37 pm    Post subject: Reply with quote
If the psp mains charger works well with tomtom, is the car charger good for tomtom too? Maplins do one with a stretchy old fashion telephone cord type. This should keep things a lot neater in the car as my current cable has a mind all if its own and gets on my nerves.
Flashyphotos
PostPosted: Thu Dec 15, 2005 7:08 pm    Post subject: Reply with quote
Yes the PSP Car charger is fine, I use one with mine as its longer than the supplied TomTom Lead.
Victor123
PostPosted: Tue Dec 20, 2005 12:39 pm    Post subject: Reply with quote
I use a Car Charger Converter - UK Adapter from
http://www.mobilefun.co.uk/product/3134.htm
It costs only £3.95 (on sale) and is free delivery for new customers.
darrenw
PostPosted: Wed Dec 21, 2005 1:05 pm    Post subject: iPAQ 4150 Power Supply Works Reply with quote
My iPAQ 4150 power supply works perfectly with my TomTom One. Wink
jonlean
PostPosted: Wed Dec 21, 2005 4:13 pm    Post subject: Reply with quote
Thanks for the tip of using PSP accessories with the tom tom
I've just been to Game and picked up a PSP dual USB and charger cable for £6.99
http://shop.game.net/ViewProduct.aspx?cat=11234&mid=326193
and it's working great for both charging and data transfer purposes!
Downward
PostPosted: Wed Dec 21, 2005 6:11 pm    Post subject: Reply with quote
That's handy - Any idea how long it would take to charge the TT ?
Could plug it in all day at work then.
jonlean
PostPosted: Wed Dec 21, 2005 6:26 pm    Post subject: Reply with quote
It's taken just over 2 hours for the battery to go from completely empty to nearly full - but it seems to be slowing down now.
Downward
PostPosted: Wed Dec 21, 2005 6:28 pm    Post subject: Reply with quote
Might have to get one - Saves messing about plugging the Cigarette lighter in for short journeys all the time.
