Pocket GPS World :: View topic - 'Recent Find' distances on i3
PeeBee
PostPosted: Fri Dec 09, 2005 7:09 pm    Post subject: 'Recent Find' distances on i3 Reply with quote
I have noticed that when I look up 'Recent Finds' the distance is shown on the right hand side of the screen but the estimate seems to be consistently understated. A recent journey of around 51 miles shows on the i3 as 34.4 miles and another journey of around 96 miles shows 73.3 miles.
I can understand some variance but this seems excessive. Have others noticed the understatement of these distances?
Comments welcomed
RODTROTTER
PostPosted: Fri Dec 09, 2005 7:18 pm    Post subject: Reply with quote
i think its has the crow flys
cantgetlost
PostPosted: Sat Dec 10, 2005 1:06 am    Post subject: Reply with quote
I understand its down to the crows as well.
PostPosted: Sat Dec 10, 2005 10:58 pm    Post subject: Reply with quote
as others have said, i think it's as the crow flies - otherwise it would take a long time to calculate each route to each point to show a proper distance!
FriendlyBloke
PostPosted: Mon Dec 12, 2005 1:04 am    Post subject: Reply with quote
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=153017&highlight=#153017
PostPosted: Mon Dec 12, 2005 11:07 am    Post subject: Reply with quote
Thanks friendly bloke, I knew it was somewhere!
Mr_Gonzales
PostPosted: Mon Dec 12, 2005 3:13 pm    Post subject: Reply with quote
Just in case...
Make sure you check the distances in a definite place, and at the same time as each other - the i3 gives the distance based on where you are at the moment, so the distance will vary depending on where you are (e.g. a location will be different distances depending on whether you are at home or at work).
And if you turn the i3 on, the distances will be out until it has a sat fix and has had the time to update the last distance readings. If I turn my i3 on right now (at work) it will give me incorrect distances for everything until it gets a sat fix, then they all update.
Likewise, when driving along and looking at favourites, fuel stops, etc. in the list, the distances to them are constantly changing, every few seconds (not that I advocate watching the i3 instead of the road...). Give it time and you might find that it just needed to catch up with you!
PeeBee
PostPosted: Tue Dec 13, 2005 12:11 am    Post subject: Reply with quote
Thanks for all your comments. Sorry I hadn't seen that other thread, FriendlyBloke, but the title didn't help!
I suppose when you think about it the unit would need to dynamically recalculate road distances for all entries in the recently found listing and we know how long it takes to calculate a route. As the crow flies can be quickly calculated by the coordinates.
Cheers all
PeeBee
22.055 (29 May 24)
