big_mike Occasional Visitor
Posted: Tue Nov 29, 2005 2:06 pm Post subject: TomTom Nav 5 "forgot" my favourites |
TomTom Nav 5 "forgot" my favourites, any idea what caused it and how I might avoid it in future? Running on a MDA compact.
TIA |
peterc10 Frequent Visitor
Posted: Tue Nov 29, 2005 4:37 pm Post subject: |
Obvious question but is your SD card write protected? |
Posted: Tue Nov 29, 2005 5:11 pm Post subject: |
SD isn't write protected. Was working fine for about 2 months and then all of a sudden "forgot" |
schneid Regular Visitor
Posted: Thu Dec 01, 2005 6:06 pm Post subject: Not the answer you are looking for |
but I convert all my favorites to POIs allowing me to backup the .ov2 files. I just use favorites as as temporary storage area. |
![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Thu Dec 01, 2005 6:16 pm Post subject: |
Hi big_mike,
Have a look at this thread, it may help!
Garmin Camper 770 LMT-D |
Posted: Fri Dec 02, 2005 11:26 am Post subject: |
Thanks for the help guys but no joy. Have checked the cfg file and it isn't write protected.
I guess it either got to warm or cold in my pocket or maybe I deleted something important removing some of the crappy media players from it.
It's stable again now '(but there again it was up until it lost it all) Would I have lost the favorites if the backup battery went flat??
Thanks again |
MGTF Occasional Visitor
Posted: Fri Dec 02, 2005 2:34 pm Post subject: |
Just had the same issue on my IPAQ5550 with TT5. Luckily i had a recent copy of the .cfg file on my PC to restore. (All my favorites are also saved as POI's but its easier i find to navigate to a favorite) |
Skids Regular Visitor
Posted: Fri Dec 02, 2005 5:14 pm Post subject: |
I have had a long running email argument with TomTom over this and they have tried to blame everything but their software!
They have said it is the speed of the SD card isn't fast enough although the problem also happens on the supplied SD card.
They have said it is due to lack of space on the SD card although I have a 512Mb card with over 300Mb free.
Their latest 'solution' was to hard reset and install the 5.21 version but don't put custom POIs on. Although I have pointed out that it also loses the settings without custom POIs installed! (Also if they produce a product that allows custom POIs they should make sure it works with them)
I am now awaiting to see what they blame next. |
Posted: Mon Dec 05, 2005 10:28 am Post subject: |
Just realised at the weekend that TT has forgotten about the speed cameras also (or maybe the warnings have vanished?) Could I have performed a hard reset by accident? Would that have removed favorites and settings? |
daern Occasional Visitor
Posted: Tue Dec 06, 2005 4:51 pm Post subject: |
Skids wrote: | Their latest 'solution' was to hard reset and install the 5.21 version but don't put custom POIs on. Although I have pointed out that it also loses the settings without custom POIs installed! (Also if they produce a product that allows custom POIs they should make sure it works with them |
Did the 5.21 update fix this, BTW. I've seen this on different combinations of SD cards and PDA, but most often on an XDAIIs and a viking 1GB (not high speed) SD card. |
Posted: Wed Dec 07, 2005 7:32 pm Post subject: |
daern wrote: | Skids wrote: | Their latest 'solution' was to hard reset and install the 5.21 version but don't put custom POIs on. Although I have pointed out that it also loses the settings without custom POIs installed! (Also if they produce a product that allows custom POIs they should make sure it works with them |
While it is working I don't want to put a patch on that might cause more problems.
I have had another reply back from TomTom who said they are not aware of anyone else but me who is encountering this problem (even though I told them a colleague at work has it!) so can I ask that you and anyone else with the same problem contact TomTom so that they can see it is a problem and they need to do something about it. |
Posted: Wed Dec 07, 2005 7:39 pm Post subject: |
Skids wrote: | I have had another reply back from TomTom who said they are not aware of anyone else but me who is encountering this problem (even though I told them a colleague at work has it!) so can I ask that you and anyone else with the same problem contact TomTom so that they can see it is a problem and they need to do something about it. |
Lying little scrotes!
I reported this 2 months ago and was fobbed off with stuff about SD cards. Noone else indeed! |
Posted: Thu Dec 08, 2005 1:45 pm Post subject: |
daern.
Please could I ask that you get back to them and tell them this. Please feel free to mention my name (Darren Skidmore) (I am sure they will remember me!)
I will do the same if you let me know your full name (pm me if you wish) and are happy for me to do so.
Maybe this will get them to look into it a bit more even though I don't think they are really interested. |
JohnMcG Occasional Visitor
Posted: Fri Dec 09, 2005 10:56 pm Post subject: |
Skids wrote: |
HAH!! I have also reported this problem within the past 1/2 months, and I NEVER got a satisfactory response.
It also forgets POI alerts, my home location, and a few other things.. |
Posted: Fri Dec 09, 2005 10:57 pm Post subject: |
PS. They blamed it on the fact I dont always go to exit before turning off the PDA.. |
