Pocket GPS World :: View topic - Suckers!
Suckers!
fwor
PostPosted: Fri Dec 02, 2005 8:09 pm    Post subject: Suckers! Reply with quote
Does anyone have any tips on what to use to clean the suction cups on PDA windscreen mounts? Mine has picked up some dirt & grease, and now dives off the screen onto the floor every 20 minutes or so...
I've tried Isopropyl alcohol on a small area, but that seems to make the surface less sticky, so probably won't help.
Also, can anyone recommend any treatment that improves adhesion (without making the fitting permanent, that is)? I suspect that silicon oil would help it stay in place, but unfortunately the residue would make a real mess on the screen, which would be extremely difficult to clean up.
TIA!
fwor
PostPosted: Sat Dec 03, 2005 7:09 pm    Post subject: Reply with quote
Thanks Dan - I've obviously not been watching the adverts carefully enough as I've never seen that tip before!
Regards
Martin
korndog
PostPosted: Sun Dec 18, 2005 9:22 pm    Post subject: Reply with quote
The ad's on local radio. Anyway the cup might be faulty, I had one that would not stick whatever I did to it. Handtec replaced it no problem :D
22.062 (12 Jun 24)
