Nick_C Occasional Visitor
Posted: Tue Aug 30, 2005 2:32 pm Post subject: POI-Warner for Mio |
POI-Warner is now available for the Mio 269 and I guess also the 268.
http://www.navigating.de/MioMap_en/POI/Index.htm
I have not given it a good test yet but it all installed fine and I have managed to get speed cameras working with it. It is all fairly straightforward, cost is about 29 euro. |
Madmouse Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_003.gif)
Posted: Tue Aug 30, 2005 10:37 pm Post subject: |
i'd appreciate some assistance on how you got pocket GPS speed camera database working? i'm a bit of a dunce & dunno where to start! |
Posted: Wed Aug 31, 2005 9:26 pm Post subject: |
It is quite simple, here is what I did.
Downloaded POI-Edit http://www.dnote.nl/pda/poi/PoiEdit/
I set it to auto update the speed camera files (its the .asc files your want) I selected the speed categorised ones, if you enable alerts, POI-Warner will then warn you if you are going too fast when approaching a speed camera.
Place the files into C:\Program Files\navigating GmbH\POI-Warner MIO Map CE Edition\pois\export. You could avoid the POI-Edit route and simple download the zip file and use those files instead.
When you run POI-Warner on your pc, select the button in the bottom left, I forget what it is called, it will copy the speed camera files to your Mio. In POI-Warner on your Mio you will need to select the speed cameras in the in the overlay and acoustic alerts dialogs. You are then ready to go.
I just need to find a replacement wav file for the alerts, the stock voice is a bit irritating.[/i] |
Posted: Wed Aug 31, 2005 9:30 pm Post subject: |
i'll give it a go
thanks for the assistance 8) |
Posted: Fri Sep 02, 2005 11:42 am Post subject: |
Thanks Nick did exactly what you suggested, works a treat on my mio 268 had an inforad detector in the car & that always seemed miss quite a fair few gatso cameras near me....this works far better can't thank you enough for the advice!!!!! |
stirling141 Occasional Visitor
Posted: Wed Nov 30, 2005 1:25 pm Post subject: |
Hi , Can any one confirm the map view for the speed camera's I've seen a few posts that say you can only see the speed camera POI in 2D map view ??
I'm after confirmation that it all so works in 3D map view aswell,
thanks :D |
Posted: Wed Nov 30, 2005 4:20 pm Post subject: |
stirling141, i've had a 268 since june this year and been using POI warner for the last few months...it's only 2D as far as i'm aware..attempted to use in 3D to no avail |
Posted: Wed Nov 30, 2005 4:26 pm Post subject: |
Thanks for the info, real shame, I guess the next option is to hack and load Tomtom 5 ,
I've seen it can be done, but is it very hard !! has any one got any recommendations on what to do ? or even if it's worth it
8O |
