dunos Regular Visitor
Posted: Tue Nov 29, 2005 7:54 pm Post subject: |
julianbarker wrote: | The last thing I want is an application bloated to support more devices when it doesn't work properly on the ones it was originally designed for. |
Agreed. If the patch only does what the website says then I won't be installing it any time soon! However if it fixes some of the issues as discussed in the bugs thread then I might actually go and find my USB cable.
Has anyone who has installed it noticed if any of the bugs have been fixed? Specifically for me the 100% cpu bug (bloody hot device) and the map scrolling when using user defined POI's that are visable on the map.
Dan _________________ http://www.durrans.com/cardspeed/ - Flash Card Speed Tests
http://www.durrans.com - In the beginning, there was nothing, which exploded. |
SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 755 Location: Biggleswade, BEDS
Posted: Tue Nov 29, 2005 8:55 pm Post subject: |
I spy with my little eye, something that has changed in V5.21....
ahhhh the version number
Have I missed the other changes, VGA mode no improvements, address look no improvement.
If this is the best TomTom can do I will not be upgrading to V6, if they ever release a new version |
TazUk Regular Visitor
Posted: Tue Nov 29, 2005 9:51 pm Post subject: |
MikeProcter wrote: | The Treos are no longer supported by Tom Tom, they are missing from the compatability list. |
As I mentioned in the other thread it depends on where you look, they are still listed on the page for Navigator 5 Bluetooth.
http://www.tomtom.com/products/features.php?ID=99&Language=1 |
MikeProcter Regular Visitor
Joined: Sep 24, 2004 Posts: 220 Location: Croydon, United Kingdom
Posted: Tue Nov 29, 2005 10:34 pm Post subject: |
TazUk wrote: | MikeProcter wrote: | The Treos are no longer supported by Tom Tom, they are missing from the compatability list. |
You are right - I looked on the wired compatability list. _________________ Skoda Columbus and for emergencies: TomTom + iPhone 4 & TomTom car kit |
julianbarker Lifetime Member
Posted: Wed Nov 30, 2005 12:24 am Post subject: |
Border_Collie wrote: | This is what I've found.
From cold. I started my stopwatch as I tapped on Tom Tom, on the main screen of my PDA. and it locked on to 5 sats in 36 seconds and by 45 seconds I had 7. A big difference from the previous 4 to 5 minutes.
On my Ipaq I never had the several minutes wait. A few seconds and I had a fix - so what else is fixed? |
mini1400 Lifetime Member
Posted: Wed Nov 30, 2005 9:28 am Post subject: |
Biggest change I can see is that I don't have to do a soft reset every time I turn my Mio 338 off.
Had to go back to V3 the other day as the soft reset button came off the PDA 8O V5 is *much* better looking than V3 and so much faster!
Typically it was while I was out and about in an area I'd never been before... must get round to soldering it back on...  |
semitone Occasional Visitor
Posted: Wed Nov 30, 2005 12:02 pm Post subject: |
I run the Palm version and the automatic recalculation after diverting from the original route is much better. It actually picked the correct alternative rather than keep trying to get be back onto the A12 this morning. |
jonmat Regular Visitor
Posted: Wed Nov 30, 2005 1:31 pm Post subject: |
How long should the update take to install? It started over 2 hours ago and is still running? Should I cancel and start again?
I am using Active Sync. |
kartracer Frequent Visitor
Joined: 26/03/2003 20:15:33 Posts: 502 Location: United Kingdom
Posted: Wed Nov 30, 2005 1:48 pm Post subject: |
jonmat wrote: | How long should the update take to install? It started over 2 hours ago and is still running? |
Depends upon your physical connection speed, i.e. serial port or USB, but either way it should take less than a minute. _________________ Kam |
Posted: Wed Nov 30, 2005 1:57 pm Post subject: |
I gave up, cancelled it and started again and it took about 30 seconds. Not sure what happened the first time. |
Gadjet Regular Visitor
Joined: 26/09/2002 08:03:29 Posts: 75 Location: United Kingdom
Posted: Wed Nov 30, 2005 3:10 pm Post subject: |
jonmat wrote: | I gave up, cancelled it and started again and it took about 30 seconds. Not sure what happened the first time. |
When I installed mine the activesync dialog appeared under the setup screen asking about default directory and it was a couple of min's before I spotted this, when I clicked OK the installation finished. _________________ www.gadjetsblog.blogspot.com |
bryanbellis Occasional Visitor
Posted: Wed Nov 30, 2005 4:26 pm Post subject: |
Mine installed easily. I chose to install to the SD card rather than the default memory position. It installed in about 30 seconds or so. All works just fine. A lot of my old favourites re-appeared. Works smooth enough. |
Posted: Wed Nov 30, 2005 8:09 pm Post subject: |
Well that was a pile of shite. I installed the update making sure to pick that I wanted it installed to my SD card. It installed to main memory Then when I tried it the main bug hasn't been fixed whereby if you have custom POI files and display them on the moving map the screen goes all jerky. Stupid TomTom. I think I might look at other sat nav systems next year. I hear some of the stand alone devices not made by tomtom can be quite good! _________________ http://www.durrans.com/cardspeed/ - Flash Card Speed Tests
gpssparky Regular Visitor
Posted: Wed Nov 30, 2005 8:36 pm Post subject: |
lbendlin wrote: | There is nothing OzVGA cannot fix. BUT you are responsible for your own eye sight... It's really tiny. |
Lutz,
Are you saying I can use OzVGA to increase the size of the compass?
How? _________________ Everywhere and nowhere
Tomtom Go 540 Live - That's it. |
prusling Regular Visitor
Joined: Jul 28, 2004 Posts: 61 Location: Poole, Dorset, UK
Posted: Wed Nov 30, 2005 9:42 pm Post subject: |
Setup installs in RAM despite selecting Built-in Storage... please can someone advise how to extract the cab file so I can use cabinstl.
Pete |
