Pocket GPS World :: View topic - TomTom 5 PocketPC v5.21 and PalmPC v5.201 Updates Released
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Mon Nov 28, 2005 10:31 pm    Post subject: Reply with quote
RobT wrote:
having the screen rotated to landscape still seems to make it run like poo in 640x480, no idea why portrait runs SO much better
Come on, get real. VGA devices have to paint four times as much screen area as QVGA devices. And then you turn the screen to landscape which requires programmatic rotating of each single frame. Of course it's slower!
Get that device a 1.2GHz processor and you'll have a fast display again.
allyourbasekris
PostPosted: Mon Nov 28, 2005 11:28 pm    Post subject: Reply with quote
So do you think there will be NO solution to the slow update in landscape mode? That's a bit of a shame if so. As it stands I don't need a mount at the moment, but I might just have to get one so I can mount my jasjar in portrait mode.
PostPosted: Mon Nov 28, 2005 11:34 pm    Post subject: Reply with quote
That may partly answer things but as the OS has native support for landscape there should be no need for TomTom to programmatically rotate the screen, they could have chosen to let the OS do this.
Why not program TomTom to check for an OS that is landscape aware and if it is let the OS handle rotation?
snark
PostPosted: Mon Nov 28, 2005 11:35 pm    Post subject: Reply with quote
What are the changes for the Palm version? I couldn't find release notes or a change log. Confused
The greatest prison is the human mind
gpssparky
PostPosted: Mon Nov 28, 2005 11:37 pm    Post subject: Reply with quote
Shame there's no real support for VGA. Compass is still tiny
Everywhere and nowhere
Tomtom Go 540 Live - That's it.
PostPosted: Mon Nov 28, 2005 11:55 pm    Post subject: Reply with quote
There is nothing OzVGA cannot fix. BUT you are responsible for your own eye sight... It's really tiny.
Talkingbollox
PostPosted: Tue Nov 29, 2005 12:29 am    Post subject: Reply with quote
I don't like the TomTom quick start hogging my Today screen. I can remove it from the Today screen in Settings/Today/Item, but how can I uninstall it altogether?
Is it the "TomTom TomTom" application?
RobT
PostPosted: Tue Nov 29, 2005 12:37 am    Post subject: Reply with quote
That's a fair point, the exec fully supports the 2 formats due to the 'flippy' nature of the screen. Like you say though it's totally useable, It's just seeing how good it looks in portrait makes me crave more! :D
PostPosted: Tue Nov 29, 2005 1:08 am    Post subject: Reply with quote
NO. that's the empty TomTom folder on the storage card.
You can only prevent the Today plugin from installing by manually extracting the files from the CAB.
However it may not be worth the effort. Once you unselect TomTom from teh Today menu it's no longer hogging anything.
PostPosted: Tue Nov 29, 2005 1:17 am    Post subject: Reply with quote
Having a flippy screen doesn't mean anything. LCD pixels come in triplets (red, green, blue) and they do that in one orientation. This happens to be the shorter side (the x axis in Portrait) - you can take a very good magnifying glass or microscope and verify that.
By the way this is also the reason why ClearType is crappier in Landscape mode - because ClearType is based on sub-pixels.
So even if your PDA comes with a "landscape" screen it will still be hardwired as Portrait, and the operating system or your application will have to do the rotation.
Again, this is a hardware based issue, and it could only be fixed with hardware - a faster processor or a graphics accelerator.
Willr2d2
PostPosted: Tue Nov 29, 2005 11:51 am    Post subject: Customised warning sounds, will they still work ? Reply with quote
Will the customised POI warning sounds still work if I install the Navigator 5.2 update on my PPC ?
If they don't should I use the same data.chk file after the update ?
Manchester
PostPosted: Tue Nov 29, 2005 12:26 pm    Post subject: Re: Customised warning sounds, will they still work ? Reply with quote
Yeah they work fine after upgrade as well as any voices you've added for directions
soweezy
PostPosted: Tue Nov 29, 2005 12:31 pm    Post subject: Reply with quote
hmmmm.... whole lot of weirdness going on here Confused
downloaded the ZIP file version and found I had to add the .zip extension to the downloaded file
then tried installing it, all seemed to go fine, but the version number hasn't changed...
anyone ??
SW
Garmin Zumo 390LM
dunos
PostPosted: Tue Nov 29, 2005 12:35 pm    Post subject: Reply with quote
Well, I have downloaded the update. However I will wait before installing it to see if anyone else finds some bugs. I currently have the first release of 5 'working' on my h4150 and if none of the issues I have have been fixed then I don't think I will actually upgrade.
I look forward to seeing the proper changelog.
Dan
http://www.durrans.com/cardspeed/ - Flash Card Speed Tests
http://www.durrans.com - In the beginning, there was nothing, which exploded.
soweezy
PostPosted: Tue Nov 29, 2005 12:44 pm    Post subject: Reply with quote
hmmmm... again
just trying to install the .exe version and it's telling me "TomTom TomTom" is already installed
not sure if the .zip upgrade asked the same, but seems odd to me...
ahhhhhhhh !!
just realised, the buttons are set to start TomTom, I just clicked on the TomTom link on the today screen and the new version started up.
so it doesn't overwrite version 5.1 and doesn't save your settings... how stupid is that ???
SW
Garmin Zumo 390LM
Page 2 of 9
23.084 (27 Aug 25)
