Pocket GPS World :: View topic - BT prob with BT-308
BT prob with BT-308
shove2001
PostPosted: Tue Nov 08, 2005 10:59 am    Post subject: BT prob with BT-308 Reply with quote
I've lost connection to my BT-308. The Blue light flashes once when you turn the unit on, then nothing. All other lights appear ok.
With no BT I can't do anything. Does anyone have any thoughts on this?
Mark
Alessandro
PostPosted: Fri Nov 25, 2005 2:24 am    Post subject: Reply with quote
Hello, I have the same problem from this evening. Only an blibk of the bluetooth status led and then enough.
What can we make?
crazybones
PostPosted: Mon Nov 28, 2005 9:57 pm    Post subject: Reply with quote
I've got the same problem suddenly with my BT308. Have you guys found a cure yet?
DTech
PostPosted: Tue Nov 29, 2005 6:20 pm    Post subject: Reply with quote
Your BT-308 Unit is Faulty.
you need to return it to your dealer for repair.
EasyD2
PostPosted: Wed Nov 30, 2005 12:25 pm    Post subject: Reply with quote
Where did you buy your BT-308. You should have a warranty with your reseller.
www.easydevices.co.uk
Tel: 0871 7000 156
Globalsat UK Distributor
crazybones
PostPosted: Wed Nov 30, 2005 9:21 pm    Post subject: Reply with quote
Sean - thanks for the reply. Unfortunately, my BT308 is over 12 months old and hence out of warranty. I'm guessing that the cost of repair & shipping will mean that it's not economic to repair.
EasyD2
PostPosted: Thu Dec 01, 2005 11:38 am    Post subject: Reply with quote
Hi crazybones.
Even if your GPS receiver is out of warranty we can still have it repaired for you if you wish. It may not cost as much as you think and it will certainly be cheaper than buying a new receiver. Give us a call on 0871 7000 156 and we'll get something sorted for you.
Tel: 0871 7000 156
miner3003
PostPosted: Thu Jan 12, 2006 10:44 pm    Post subject: bt 308 Reply with quote
Can't seem to pair my bt 308 with a Ipaq 3970
what is the passkey code for the bt 308?
i think i booted my box and sheet out!! seem to remember a number being used i think??
Saying that it will pair with the Ipaq if i use memory map!!
Odd! is there a pairing post i could refer too? i have loked around the site but there is a mass of info up here.
cheers guys
EasyD2
PostPosted: Fri Jan 13, 2006 1:17 pm    Post subject: Reply with quote
Your passkey should be 2003
Tel: 0871 7000 156
miner3003
PostPosted: Tue Jan 17, 2006 12:43 am    Post subject: Reply with quote
Hey --- You da Man!
That worked superbly, just need TT5 to find it and i should be away
