johnboy1888 Occasional Visitor
Posted: Wed Nov 23, 2005 6:36 pm Post subject: Please help |
Hi wondering if anyone can help. My xda runs tom tom 5, but it never saves anything when you close the program.. It is installed onto the sd card, does anyone know how to make it save thing like home address, poi warnings, as eveytime i turn it on i have to put it all in again. Thanks for you help.
John |
StevenGourlay Frequent Visitor
Posted: Wed Nov 23, 2005 6:49 pm Post subject: |
is your memory card write protected?
do you use the exit application button when finished with tomtom? _________________ Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool |
Posted: Wed Nov 23, 2005 7:03 pm Post subject: Not Locked |
No the card is not locked if thats what you mean. and yes i stop tom tom, by the exit app.. It has saved the extra cams i put on in poi, but thats all it will do
john |
Joined: 30/12/2002 17:36:20 Posts: 4921 Location: Oxfordshire, England, UK
Posted: Wed Nov 23, 2005 7:10 pm Post subject: |
Hi johnboy1888,
to the forum!
Does your config file (*.cfg in your map folder) have a property of "Read Only"?
Garmin Camper 770 LMT-D |
Posted: Wed Nov 23, 2005 7:10 pm Post subject: No, it has loads |
No it has loads of room on it. its a 512 and only tom tom is on it. Thanks |
Posted: Wed Nov 23, 2005 7:15 pm Post subject: CFG file |
I have looked in the map folder, but cant see a cfg file, is it hidden somewhere else?
Thanks robert |
Posted: Wed Nov 23, 2005 7:37 pm Post subject: |
Hi johnboy1888,
It's either/or:
Great_Britain-Map.cfg
Great_Britain_Plus-Map.cfg
Posted: Wed Nov 23, 2005 7:38 pm Post subject: oops |
I found he config file, and yes its read only, but will not let me change it.. how do i change it?
John |
Posted: Wed Nov 23, 2005 7:44 pm Post subject: no sorry |
the one i found was called ms office config file, cant find the one you are on about.. its not there, the onlt thing i have under GB is a midi file, a pna file the one i mentioned and a macpaint image....
cheers john |
Posted: Wed Nov 23, 2005 7:51 pm Post subject: |
It should be in the map folder on your storage card.  _________________ Robert.
Posted: Wed Nov 23, 2005 7:57 pm Post subject: only one |
the only one there is this one Great-britain-map------- microsoft office outlook configuration file and its 127kb....... is that the one. if it is, then its read only and it will not let me change it
cheers
john |
Posted: Wed Nov 23, 2005 10:19 pm Post subject: |
Hi johnboy1888,
Copy the Great_Britain-Map.cfg file (from your map folder) to your PC, remove the Read-only property from the Great_Britain-Map.cfg file.
Copy the Great_Britain-Map.cfg from your PC back to the map folder on your PDA.
You may want to make a backup of the Great_Britain-Map.cfg before you change it - just in case.
Posted: Wed Nov 23, 2005 11:03 pm Post subject: sorry |
sorry to be a pain, but i did that and when i put it back onto pda, it turned it stright back to read only again. any other ideas or should i just put up with inputting everytime i turn it on.... is this normal or do i want something that does not normally happen
cheers
john
pps thanks for you help robert |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Thu Nov 24, 2005 7:59 am Post subject: |
Did you delete the original file on the PDA before trying to copy the new file from PC.
If you didn't when you try to copy from the PC it won't overwrite it because of the Read Only on the original file. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
