Pocket GPS World :: View topic - speed camera locations
brettytopbanana
PostPosted: Mon Nov 21, 2005 8:38 pm    Post subject: speed camera locations Reply with quote
having just bought my i3 i thought i would load up all the poi's and speed camera locations following the guide on the forum
i made a folder called poi & speed camera and then unzipped the poi's and speed camera locations into there. i noticed that all the poi's were showing but the speed camera locations were stored in other folders within this folder. one of the folders was called speed zoned.
when i connect the i3 to my computer and poi loader starts up am i supposed to browse to the folder that comtains everything (so in my case it would be the poi & speed camera folder) or do i have to browse to the other folders within this folder.
the reason i ask is i just took the i3 to a few gatsos and it didnt pick up a thing.
anyone know what ive done wrong and why t isnt working?
thanks
craig
MELennium
PostPosted: Mon Nov 21, 2005 9:26 pm    Post subject: Reply with quote
Welcome brettytopbanana
In the speed camera folder, find the csv files folder & then the other folder where you will find the right files, you will also need the 6 bitmaps from the ov2 bmp files folder but not the other files in this folder then download to your i3.
But a better way would be to use csv files from above then the bitmaps from Mafts site which also includes loads of POI's.
http://www.MaFt.co.uk/garmin/download.htm
MELennium
PostPosted: Mon Nov 21, 2005 9:40 pm    Post subject: Reply with quote
Forgot to mention, if you do use MaFt's files (Highly recommended) then make sure to use the CamRename.bat file which changes the csv file names to the same as MaFt's bitmaps.
brettytopbanana
sorry mate i still dont understand it but when i download the pocket gps world speed camera database i extract all the files to my POI & SPEED CAMERA folder. then what do i do, i really dont understand it.
sorry to be a pain!!
brettytopbanana
PostPosted: Mon Nov 21, 2005 9:45 pm    Post subject: Reply with quote
ok i understand what you mean now but i also followed another link which i downloaded the garmin speed camera database any ideas what i have to do now?do i have to copy the files that you talked about to this GARMIN folder or shall i just upload the whole folder which contains everything to my i3?
MELennium
PostPosted: Mon Nov 21, 2005 10:00 pm    Post subject: Reply with quote
Right lets try again
After you have downloaded the speed camera files from PGPSW & unzipped to a folder of your choice ie Speed Camera folder. Look for a folder called csv files, open this folder then look for the other folder wher the 6 files are & copy these to your POI & SPEED CAMERA folder.
Now go to MaFt's site & you will see a file called GarminPOIs.zip, download this file & unzip to your POI & SPEED CAMERA folder. You now should have loads of POI's, 6 bitmap camera files & the csv camera files, also a file called CamRename.bat. Click on this file & it changes the csv file names to MaFt's file names. Now download to your i3 using the Garmin POI Loader.
brettytopbanana
PostPosted: Mon Nov 21, 2005 10:05 pm    Post subject: Reply with quote
right i have got you, so basically the garmin speed camera folder which is downloaded from another site is not needed all i need is the poi's and the camera database from mafts site and that is it?
Minidish
PostPosted: Mon Nov 21, 2005 10:08 pm    Post subject: Reply with quote
Create a folder on your harddrive, call it what you like, then unzip the Garmin database into new folder now connect your I3 and run POI-Loader then browse to new folder and either upload Manual or Automatic.
If you want to upload other POI's to I.3 ensure they are all in one folder.
The Garmin database as speed zoned all ready for you which includes BMP's with appropriate speeds i.e 20mph 30mph 40mph etc
Hope this clears the mud a bit Smile
Best regards
Minidish
Etrex Vista Hcx Ver. 3.60
TT XL, Europe 31 Special Edition
TT Home V2.5.2.60
CamerAlert on Galaxy S2
Wife 4 backup
MELennium
PostPosted: Mon Nov 21, 2005 10:10 pm    Post subject: Reply with quote
No not quite, you still need the files from PGPSW but only the 6 i mentioned earlier in the other folder as these are the only ones that work with the i3, the rest are for different sat nav systems.
brettytopbanana
PostPosted: Mon Nov 21, 2005 10:13 pm    Post subject: Reply with quote
ok mate i have done that , i have uploaded the folder with all the poi's in and the 6 bmp files and the csv cmera files. do i upload the new folder with the garmin database in seperately?i will get there in the end!!
MELennium
PostPosted: Mon Nov 21, 2005 10:17 pm    Post subject: Reply with quote
Minidish is right if you are just using the other link but i prefer MaFt's files as they more condensed & with the z in front of all his files, means they are right at the bottom of all the POI's list.
brettytopbanana
PostPosted: Mon Nov 21, 2005 10:19 pm    Post subject: Reply with quote
right well i have done that then,thanks a lot for your help, as for it picking up the speed cameras ill it just do that automatically or do i have to click on them in the list?
MELennium
No not required if you have done first method.
MELennium
PostPosted: Mon Nov 21, 2005 10:22 pm    Post subject: Reply with quote
Automatically.
Minidish
PostPosted: Mon Nov 21, 2005 10:39 pm    Post subject: Reply with quote
Please correct me if I'm wrong or misunderstood but.....
I assume that by using the 6 bitmaps you mention you don't get a speed alert that shows the actual speed limit?
The speed zoned database has 15 bitmaps which it needs to show speed limits ranging from 20mph to 70mph and various bitmaps for various cams, i.e Mobile, Temp, Gatzo etc.
Best regards
Minidish
TT Home V2.5.2.60
Wife 4 backup
22.062 (12 Jun 24)
