tubbs Occasional Visitor
Posted: Fri Nov 18, 2005 12:41 am Post subject: out of my depth- help needed in laymans terms |
i started out with hp navigator 4 with ipaq 1710.
this was upgraded to navigator 5. then, to rid myself of cables i upgraded to ipaq 2110 and syson bluetooth gps plus.
i have tried numerous ways to load tomtom but have not managed to successfully do this.
if anyone could give me advice in simple terms, i would be very grateful. |
lbendlin Pocket GPS Staff
Posted: Fri Nov 18, 2005 1:02 am Post subject: |
what's the current status - did you manage to install TTN on the new PDA yet? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Nov 18, 2005 1:07 am Post subject: status |
at the moment, the position is that i have installed the maps to the sd card, but on the pda there is no shortcut available. the last attempt loaded the tomtom, but it could not find any maps, so i deleted the program and started again. |
Posted: Fri Nov 18, 2005 1:18 am Post subject: a bit more information |
just thought, i am trying to do this with a card reader, not by synchronising computer. i wondered if this made a difference. |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Fri Nov 18, 2005 2:07 am Post subject: |
Some card readers will load the data to the card that can be seen on your main pc ok, but cannot be seen on the PDA. Yes, try ActiveSync, takes for ages, and sometimes looks like its restarting when sending the map data to the card on the PDA, but its not, just wait and it should complete ok. Could be between 30-50 minutes. |
Posted: Fri Nov 18, 2005 2:17 am Post subject: |
you should never install maps through ActiveSync. The TomTom installer gives you the option to install to storage card reader, and you should take that offer.
The application however can be installed through ActiveSync, and this should not take very long. _________________ Lutz
Posted: Fri Nov 18, 2005 2:34 am Post subject: progress report |
i have just tried installing via sync. but the only programs i find in add/remove programs are great britain map and zip. the application does not appear |
Posted: Fri Nov 18, 2005 2:53 am Post subject: |
Let me rephrase. The application can be installed with the TomTom installer when the Pocket PC is connected to the PC. So ActiveSync is not (directly) involved (but a connection should exist). _________________ Lutz
Posted: Fri Nov 18, 2005 3:00 am Post subject: i apologise for my ignorance |
this might seem a silly question, but how do i get the application to load on the pda? i have just run setup again but it just wants to install maps again. |
Posted: Fri Nov 18, 2005 5:25 am Post subject: |
You need to use the first CD to install the application. All the other CDs only allow you to install maps. _________________ Lutz
Posted: Sat Nov 19, 2005 1:06 am Post subject: still not happening! |
i have been using cd1, but it has not loaded the application |
Posted: Sat Nov 19, 2005 2:10 am Post subject: i just dont know |
the only way i have been able to get the application on my pda, is to use the navigator 4 sd card that i originally got. this is now not valid to activate as i upgraded. have tried to use cd1 of navigator 5 from this position but still get nowhere. i am sorry if you feel i am a numbskull!!, but i haven't got a clue what to do next. |
Oldboy Pocket GPS Moderator
Posted: Sat Nov 19, 2005 9:40 am Post subject: Re: still not happening! |
tubbs wrote: | i have been using cd1, but it has not loaded the application |
In the complete TTN5 package you should have 7 CD's. CD1 - 6 contains the maps. The 7th CD contains the Application.
They are numbered 1-6 because the same CD's are used by the GO, but it doesn't need the application CD. _________________ Richard
Posted: Mon Nov 21, 2005 2:20 am Post subject: THANKS TO ALL |
cheers for all your help, everything is hunky dory now and working well.
as i said at the beginning, i am not a techi, but not even to use the right disc, what an idiot!!!! |
davast Lifetime Member
Joined: 19/08/2003 20:59:33 Posts: 61 Location: Warrington UK
Posted: Mon Nov 21, 2005 2:24 pm Post subject: |
Can you tell me which CD the UK maps are on as I cannot find them? |
