RS2000 Occasional Visitor
Joined: Dec 28, 2003 Posts: 49 Location: Waltham Cross, Hertfordshire
Posted: Wed Nov 02, 2005 8:22 pm Post subject: No com port 7 on TT5? |
After using TT3 i've had no prob's. But now using TT5 i cannot get it to list a com port 7 for my BT globalstat 308 receiver. I have tried port 5, 6 & 8 as they're the only 1's that are listed, but it wont find my receiver.
I can connect ok in the bluetooth manager showing a perfect reception.
(Using Fujitsu Siemens LOOx 410)
any idea's.
Thanks. |
lbendlin Pocket GPS Staff
Posted: Wed Nov 02, 2005 9:36 pm Post subject: |
your TT3 GPS driver is probably hiding the port. Uninstall that driver.
By the way, it doesn't have to be COM7: - whatever the BT settings show as outgoing serial port needs to be used. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Nov 02, 2005 10:01 pm Post subject: |
It's a new PDA. TT3 was on the old 1.
BT settings show : Inbound Port 8. Outbound Port 6.
Only it wont find the BT receiver on either of them? |
Posted: Wed Nov 02, 2005 10:20 pm Post subject: |
you MUST use COM6 then.
It probably doesn't find the receiver because you have set it to SiRF protocol with TTN3. TTN5 only understands NMEA, and you need to reprogram the receiver to NMEA. _________________ Lutz
Posted: Wed Nov 02, 2005 10:33 pm Post subject: |
Is that very hard to do, i didn't know you could reprogramme receivers? _________________ WARNING: To much chocolate can make your clothes shrink. |
Posted: Fri Nov 04, 2005 4:30 pm Post subject: |
Am i right in thinking that it just needs to be left switched on for 48 hrs after the battery has completely exhausted & then it resets back to factory settings?
If i done that would it work then? Only the BT-308 is supposed to be NMEA compatible isn't it?
Fanx.
Posted: Fri Nov 04, 2005 5:05 pm Post subject: |
either that or you can use WinFast Navigator or similar on the PDA to switch protocols _________________ Lutz
Posted: Sat Nov 05, 2005 12:14 pm Post subject: |
tried WinFast Navigator but still not find it, looks like i have 2 leave it switched off for 2 days. _________________ WARNING: To much chocolate can make your clothes shrink. |
