Springer Occasional Visitor
Joined: Oct 16, 2005 Posts: 11 Location: New Jersey, USA
Posted: Sun Oct 30, 2005 3:15 am Post subject: |
Nevermind!!
I think it needed a restart. Working now.
Thanks again to all for the great tips.
:D |
Radek Occasional Visitor
Posted: Sun Oct 30, 2005 10:05 pm Post subject: |
Hi, I really want to get this up and running but I’m still having problems accessing the registry on my 510….tried all suggestions re disconnecting, resetting, etc but Registry Workshop (or other similar apps I’ve tried) wont recognise it. Any suggestions? Thanks. |
Dilemma Regular Visitor
Posted: Sun Oct 30, 2005 10:33 pm Post subject: |
You will need to give me a little info before I can help. |
Posted: Sun Oct 30, 2005 11:05 pm Post subject: |
Radek wrote: | Hi, I really want to get this up and running but I’m still having problems accessing the registry on my 510….tried all suggestions re disconnecting, resetting, etc but Registry Workshop (or other similar apps I’ve tried) wont recognise it. Any suggestions? Thanks. |
When the Registry Workshop launches it will open your PC registry by default. First make sure the device is connected and ActiveSync sees it. You must then click the "Connect Mobile Device Registry" icon on the Reg, Workshop tool bar. It looks like a PDA. You can also access it by clicking on "File" and then select "Connect Mobile Device Registry".
When it sees the registry it should show the four main keys. Click on the + next to HKEY_LOCAL_MACHINE. It will open the list. Click on the init item. The screen should look like this.
Double click the Launch80 item. It should open a window that looks like this.
Change the second line so it says PocketPC.exe
That should do it. Just close the application. If it won't display the keys close and reopen the application. Sometimes it has taken a few tries to get it to work.
Hope this helps. |
Posted: Mon Oct 31, 2005 12:46 pm Post subject: |
Springer, thanks for these beautiful step-by-step instructions. All working now! |
scrivomcdivo Occasional Visitor
Posted: Wed Nov 02, 2005 4:39 pm Post subject: |
Could anyone provide the direct link for GPSpassion? I have gone to the site, but can't find the instructions within the site |
nortonbeak Regular Visitor
Joined: Oct 08, 2005 Posts: 186 Location: North East, England
UpAllNight Occasional Visitor
Posted: Thu Nov 03, 2005 1:38 am Post subject: |
After using TT5 on my icn510 for the past few weeks(Thanks to this guide!), I can safely say i'm never going back!! I get GPS locks much, much faster (under 2 min even when moving, as opposed to about 2 min when stopped and 10+ minutes when moving while using smartst), there are far better routing options, the voices are louder/clearer, and the software is just more inituitive, more powerful, and easier to use overall. The only shortcoming is that (to the best of my knowlesge) there is no way to log routes. |
navmanguy Occasional Visitor
Posted: Thu Nov 03, 2005 8:41 pm Post subject: |
Do you have to have a 128mb card to install tt5 on the icn520?
Dont think the original sd card is that high.
Can you delete the navman data from it and install the tt data to be able to fit it on? |
Posted: Thu Nov 03, 2005 8:51 pm Post subject: |
navmanguy wrote: | Do you have to have a 128mb card to install tt5 on the icn520?
Sorry 256mb reported to be needing and my card is a 244.7mb |
Clogs Occasional Visitor
Posted: Fri Nov 04, 2005 9:45 am Post subject: Alternate GPS Capability |
Has anyone found software suitable for 510 use under WINCE which gives a GPS capability where you can load co-ordinates and an arrow points in the right direction ? |
RobM2208 Occasional Visitor
Posted: Fri Nov 04, 2005 5:16 pm Post subject: |
Hi all
I have read through this entire thread and been fascinated if somewhat confused. The original thread named a guy called Alex and a link to a site. Having just bought my Navman 520 (yesterday) due to TT go being far more expensive I would like to know a couple of things.
1. Does the link to the site unloock the navman only and if so do you then need to add a different OS onto it to allow you to install TT5
2. Does the link give you a copy of TT5 or do you need to acquire this elsewhere
3. Is the card I have in the Navman an SD card or MMC card as TT5 needs an SD card
4. I have an SD card with TT5 installed in my PDA. Can I just unlock the Navman and then swap cards to get TT5 on the Navman or is there some install/config work I need to do also
Any help greatly appreciated
Rob |
mbriody Occasional Visitor
Posted: Mon Nov 14, 2005 12:21 pm Post subject: |
I am using pr24's hack (from GPSPassion) and can get TomTom 5.1 running on my ICN 510.
Of course this is lost whenever I do a cold reset. What I am trying to do is create a backup on SD (512Mb) which I can copy back over using FileMan after a reset without having to use a PC. This is almost but not quite working.
When TomTom is working I have the following in main memory:
\Program Files\Navigator\data.chk
\Program Files\Navigator\navigator.cfg
\Program Files\Navigator\TomTom Navigator.exe
\TomTom\go1108m.wav
\TomTom\tttoday.dll
\TomTom\TomTom\data04.chk
and my maps are stored on the root of the SD.
I took a backup copy of these directories onto SD. My restore sequence is as follows:
1. reset the machine - Navman is reinstalled and pr24's menu app is started.
2. run Fileman and delete \Program Files\Navman to make some space in main memory.
3. copy \program files\Navigator and \TomTom backups from SD to main memory.
4. Use FileMan to launch TomTom.
This starts up okay but instead of going into the app it starts at the agreement screen and when I select okay it locks up.
There is obviously something I am missing.
Anyone got any ideas? |
mrg2003 Regular Visitor
Joined: 12/03/2003 18:19:15 Posts: 136 Location: United Kingdom
Posted: Fri Nov 18, 2005 11:04 pm Post subject: navman 510 tt5 restore |
I've tried sprite backup, sprite clone and HP backup/restore. AFAICT it should wouk, but it hangs. I suspect a crc failing on the navman installer, if it detects the run key is changed. I can do a cradle restore that works 6/10, but
1. it takes ages
2. If you need the lead, you might as well re-install from the PC anyway.
Not much help, sorry. |
scoobynutter Occasional Visitor
Posted: Tue Nov 22, 2005 11:30 am Post subject: |
hi all new to this forum looks like there some great stuff going on here .i got a navman icn 520 and got the menu all up and running but am struggling with how to put tomtom5 on there any help would be great
cheers paul |
