Pocket GPS World :: View topic - o2 xda help
o2 xda help
baadboy
PostPosted: Fri Oct 21, 2005 3:33 am    Post subject: o2 xda help Reply with quote
hi all,i would appreciate very much some help.i have d/loaded ttn5 onto my p/pc. all seems ok except at the bottom left it says no gps device.i am not upto date with all this , so can someone please forward detailed instructions as to how i can resolve this. i have a cabled gps receiver.thanks to all in advance
PostPosted: Fri Oct 21, 2005 3:39 am    Post subject: Reply with quote
Please have a read of this lot - it should answer your problems
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=28396
Mike
baadboy
PostPosted: Sat Oct 22, 2005 12:04 am    Post subject: o2 xda Reply with quote
hi,thanks for your reply.much appreciated.can you please further advice me as to what you mean regarding the ex.keyboard device driver and program comm port/irdaand how to proceed from selecting the corporate mode.thanks again
PostPosted: Sat Oct 22, 2005 12:16 am    Post subject: Reply with quote
Once corp mode is entered proceed with a normall TomTom install and registration, a back up is of little use (as depicted in the original link), to disable the IRdA you need to go to settings, conection IRdA and de-select the check box for "recieve all beams" - the key board stuff is only if you have an external keyboard driver programe loaded, if so open it up and select serial/ IRdA instead of Keyboard - read the link its all in there as far as I can remember - mike
PostPosted: Sat Oct 22, 2005 12:21 am    Post subject: Reply with quote
I suspect the problem is probably the IRdA, so follow the above advice, then with the correct settings in TT (other cabled NMEA device, set the Baud speed for your GPS device, then select the port COMM 1) - take the whole lot outside with a decent line of sight to the sky and wait - it could take ten min - check progress in the GPS settings screen in preferances, you should see it lock on to where you are. - Mike
baadboy
PostPosted: Sat Oct 22, 2005 3:14 am    Post subject: xda Reply with quote
hey thanks again mike.will follow your info and will update you.cheers mate
