Pocket GPS World :: View topic - Battery Life
Battery Life
Goto page 1, 2, 3  Next
casablanca
PostPosted: Thu Oct 06, 2005 9:20 pm    Post subject: Battery Life Reply with quote
I only use my i3 in the car plugged into the cigar lighter. The only time the battery is in use is when I turn off the power and the unit says that it will switch off in 30 seconds.
I have now put in my third set of batteries in 10 days. I only do one trip a day so I am averaging batteries every five days with 30 seconds of battery use a day. Surely this can't be right.
zogman
PostPosted: Thu Oct 06, 2005 10:09 pm    Post subject: Reply with quote
garmin site states that the typical use is 6 hours....it all also depends on what type of batterys you use.i use duracell and i do the same as you and only use the power cable.my batterys have lasted me about 4 weeks now.
FriendlyBloke
PostPosted: Thu Oct 06, 2005 11:48 pm    Post subject: Re: Battery Life Reply with quote
I agree , I don't think it is right. I have had duracell in mine for a month and still got three bars. Have you tried the unit without batteries while plugged into the mains to see what happens? Bit of a mystery, sorry can't be of more help. Confused
casablanca
PostPosted: Fri Oct 07, 2005 9:24 am    Post subject: Reply with quote
I'm wondering if the USB plug is not switching off the battery when engaged so that the battery still has an output even though there is a feed through the USB.
zogman
PostPosted: Fri Oct 07, 2005 9:26 am    Post subject: Reply with quote
or cheapo batterys........
casablanca
PostPosted: Fri Oct 07, 2005 9:31 am    Post subject: Reply with quote
I have now fitted re-chargeable 2500mAH Ni-Mh. See if they do any better.
Anyone know when you select Ni-Mh on the menu the i3 re-charges them?
kartracer
PostPosted: Fri Oct 07, 2005 10:20 am    Post subject: Reply with quote
The i3 does not recharge its batteries, but rechargeables should last much longer than alkalines when used in it. Sounds as though yours is faulty though.
Kam
Terrystan
PostPosted: Fri Oct 07, 2005 12:53 pm    Post subject: Reply with quote
The reason for the Alkaline / NiMH option is that battery life is determined by the discharge curve which is different for both types so if the wrong type is selected the unit could determine the battery is flat long before it really is, As a general rule re-chargables have less capacity than good Alkalines.
RichardCr
PostPosted: Fri Oct 07, 2005 1:00 pm    Post subject: Re: Battery Life Reply with quote
Does you i3 start automatically when you turn the ignition or plug it in with the car running? It should. If not you may not have plugged it into the cigar lighter socket properly (easy to do) or there's a fault in the connector. Pretty basic I know but sometimes its easy to miss the obvious.
casablanca
PostPosted: Fri Oct 07, 2005 1:27 pm    Post subject: Reply with quote
Yes, starts up straight away when I turn on the ignition and shuts down with the 30 second message when I switch the ignition off.
zogman
PostPosted: Fri Oct 07, 2005 1:32 pm    Post subject: Re: Battery Life Reply with quote
if this is the case dont put any batterys in it!...
casablanca
PostPosted: Fri Oct 07, 2005 1:38 pm    Post subject: Reply with quote
Good thinking, but I would probably lose information.
zogman
PostPosted: Fri Oct 07, 2005 1:42 pm    Post subject: Reply with quote
dont think you will...imagine the i3 with flat batterys -still got the info on it...
casablanca
PostPosted: Fri Oct 07, 2005 1:59 pm    Post subject: Reply with quote
I'm leaving the unit plugged into the PC all day and will check battery life tonight.
I can't find the three bars mentioned in an earlier link, only the signal bars.
Where are they.
zogman
PostPosted: Fri Oct 07, 2005 2:05 pm    Post subject: Reply with quote
the battery indicator is on the very 1st page at the top along with signal strength and time ....
Page 1 of 3
22.062 (12 Jun 24)
