Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Mon Oct 03, 2005 6:21 pm Post subject: Re: Differences between 510 & 520 |
davebbrannigan wrote: | The Curmaps .ini file is split into many sections, each having a line reading "sounds = " with no data entry after the equals. I'm sure that if we knew where to actually put the .wav file we could add a data entry here and it would have some effect. Anyone out there tried this? |
The .ini file you mention also appears in the 510 and also in the PDA version. People tried to edit toat file on both of the above platforms without success. _________________ Tim |
Dilemma Regular Visitor
Posted: Tue Oct 04, 2005 6:50 pm Post subject: Re: Differences between 510 & 520 |
Tim Buxton wrote: | davebbrannigan wrote: | The Curmaps .ini file is split into many sections, each having a line reading "sounds = " with no data entry after the equals. I'm sure that if we knew where to actually put the .wav file we could add a data entry here and it would have some effect. Anyone out there tried this? |
The .ini file you mention also appears in the 510 and also in the PDA version. People tried to edit toat file on both of the above platforms without success. |
Actually it does work, and works exactly as described in the earlier post. |
Posted: Tue Oct 04, 2005 7:14 pm Post subject: |
Dilemma,
Are you saying that you can assign one sound per Custom POI category? _________________ Tim |
Posted: Tue Oct 04, 2005 7:19 pm Post subject: |
Yes, providing that you remember to also change both the file in the "My POI" directory of the CD card as well as the corresponding file in the backup directory within the "Flash Disk". |
Posted: Tue Oct 04, 2005 7:25 pm Post subject: |
Sorry reply was not very useful when read again. What you need to do is to download a series of small .wav files to your "My POI" directory on the SD card. You then edit the individual POI file (appears as a note pad with a cog in the middle). You need to add the line "soundfile=****.wav", where "****" is the sound file you have already placed in the directory. Once done copy the files and overwrite the equivalnet ones on the flash disk. |
Posted: Tue Oct 04, 2005 7:32 pm Post subject: |
Well thanks for that. It's something I've been trying to do on my PPC version for ages, without success. I wonder if it will work on that and on my iCN635, too.
So much to do, so little time..... _________________ Tim |
Posted: Tue Oct 04, 2005 7:42 pm Post subject: |
No worries, good luck. |
Simon1 Frequent Visitor
Posted: Wed Oct 05, 2005 8:39 pm Post subject: |
For the less brave amongst us, let us know how you go, Tim! |
davebbrannigan Occasional Visitor
Posted: Fri Oct 14, 2005 6:47 pm Post subject: |
I followed the instructions posted by Dilemma to add custom soundfiles and initially had great success. The newly added file played when proximity to one of the programmed POIs was reached. However, I since found that at some point through my journey the iCN stopped playing any sound for either POI's or voice directions. Is there a chance that if the unit tries to play both at the same time it could hang up? I think that for now I will edit the POI ini files back to original and see if everything reverts to normal and I'll keep an eye out for suggestions. |
Noonster Regular Visitor
Joined: Nov 08, 2005 Posts: 83 Location: East Yorkshire, UK
Posted: Wed Nov 09, 2005 8:12 pm Post subject: |
shughie wrote: | Hi chill
The free download is the one you want, open it and you will see `csv files` (4th one down) open that and you will see `other` (4th one again) they are the files you want to copy to your 520. I have a 520 and they work a treat.
shughie. |
Any ideas where you can get all the cameras in ONE POI instead of having them all seperate? As I would just like to use the Speed Camera bmp you get with the unit and also save POI selection space by only having to select 1 instead of say 18.
Cheers _________________ Noonster
Getting a TomTom 510 |
Posted: Wed Nov 09, 2005 8:18 pm Post subject: |
Please ignore the above post....
- As I have posted it in another thread and then had a memory lapse and forgot before posting the one above! _________________ Noonster
Oldboy Pocket GPS Moderator
Posted: Wed Nov 09, 2005 8:21 pm Post subject: |
Noonster wrote: | Any ideas where you can get all the cameras in ONE POI instead of having them all seperate? As I would just like to use the Speed Camera bmp you get with the unit and also save POI selection space by only having to select 1 instead of say 18. |
It's in the Folder 'single file version\asc file\' and is named, unfortunately, pocketgps_gb_gatso.asc _________________ Richard
Posted: Wed Nov 09, 2005 8:25 pm Post subject: |
Oldboy wrote: | Noonster wrote: | Any ideas where you can get all the cameras in ONE POI instead of having them all seperate? As I would just like to use the Speed Camera bmp you get with the unit and also save POI selection space by only having to select 1 instead of say 18. |
It's in the Folder 'single file version\asc file\' and is named, unfortunately, pocketgps_gb_gatso.asc |
Thats so even though named gatso it has everything that the 5 or 18 seperate ones have.... thats good :D
How does it no to use the speed camera bmp that you get with the iCN520 unit and is there a link that shows a step by step guide on how to add them to the unit (where to put them etc...)
Thanks :D _________________ Noonster
Buddhainuk Occasional Visitor
Posted: Thu Nov 10, 2005 8:12 pm Post subject: |
Hi guys
Just got my iCN520 really like it now i want to install the speed cameras file,
Can some one point me to the right file please what is it called or can they put up a link to it please.
Big thanks for any Help. |
