big-al-13 Occasional Visitor
Posted: Sun Sep 25, 2005 12:33 am Post subject: activation code help please |
hi
i have a ipaq hx4700 and have just purchased TomTom 5 with UK and Europe maps, i installed tomtom on to the ipaq then added the UK map and post codes, now the problem is i went onto ttcode filled in my product code then my device code and they gave me a activation code now when i start tomtom i get to the uk map wich needs activation i put in the code i got from tomtom and it says this is not the correct activation code for Great Britain
what did i do wrong???????? |
alix776 Pocket GPS Moderator
![](modules/Forums/images/avatars/6212487444319be6786243.jpg)
Posted: Sun Sep 25, 2005 12:54 am Post subject: |
sounds like you put the wrong device code in to tt code go back to ttcode and check te code is correct when you have it working youll need to update to the v5.1 fom the tomtom website as it contains a fix for the vga screen _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun Sep 25, 2005 1:15 am Post subject: |
HI
i wish it were that simple, i have checked and the codes i put in are the ones i got from tomtom
its something so simply it just cant go wrong but it has i am begining to think its a software bug
i have filled out there online support form but i thought someone here might be able to shed some light on it
HELP |
Posted: Sun Sep 25, 2005 1:23 am Post subject: |
did you try the code ont the sleeve first _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sun Sep 25, 2005 9:46 am Post subject: |
no
what do you mean on the sleeve first
how do i do that |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Sun Sep 25, 2005 10:44 am Post subject: |
The registration number you need to use should be printed on a credit card size plastic card retained on the inside of the fromt cover - this all worked fine for me as I have just put UK on the PDA from the full European set. I just can't get the free traffic trial to work! - Mike |
Posted: Sun Sep 25, 2005 11:10 am Post subject: |
mike for traffic you need to set the device again for tt traffic _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sun Sep 25, 2005 11:13 am Post subject: |
I've been try that Andy sugested trying to register with the device undocked and performing via GPRS which I have tried but that didn't work either - will try the phone call to TT in the morning - Mike |
Posted: Sun Sep 25, 2005 1:12 pm Post subject: |
hi
i used the number on the credit card
could it be the wrong credit card for the software ???
as for automated activation the page it sends you to is not there so it wont work either
i emailed the shop from where i got it and they said this is not the first time they have had problems with tomtom activation wait 7 days then try again to activate it, cant see what difference this would make apart from then not getting hassle from me as i have asked either to get the software running or a refund |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Mon Sep 26, 2005 1:50 pm Post subject: |
big-al-13 wrote: |
The 7 days is the time it takes to activate it on a second device. Which means the shop you got it from could be illegally duplicating the software?
Check it to make sure it is genuine. |
Posted: Tue Sep 27, 2005 12:24 am Post subject: |
MarkHewitt wrote: | big-al-13 wrote: |
hi i have posted the software back and now waiting to get a refund
tried PC World but they are out of stock so i guess i will just have to try my luck with another on line shop and hope for the best
cheers guys for all your help |
