Pocket GPS World :: View topic - Back up of SD card-fall at first hurdle!
smitty03
PostPosted: Thu Sep 15, 2005 9:19 pm    Post subject: Back up of SD card-fall at first hurdle! Reply with quote
TTG300 Viking 256mb SD (Japan) App 5.201 OS:908 Map v562
Apologies if answer already in forum but so much useful info I can't find it.
As recommended, trying to back up original SD onto Viking card before copying over Speed Camera files. Files appear to be a mirror image of those on original TTG card but when switching on TTG the infamous SD card with red cross appears.
I have tried doing back up via both the TTG and card reader but neither works.
Also, should I be able to get the SC files on the original card?
Help!
Thanks in advance.
rugrat2
PostPosted: Thu Sep 15, 2005 9:41 pm    Post subject: Reply with quote
So are u saying that u cannot copy the files of your card via a card reader to your hard drive?
smitty03
PostPosted: Thu Sep 15, 2005 10:21 pm    Post subject: Reply with quote
No. Using both methods, the SD card appears to be holding all the right files following copy from original SD to HD then from HD to larger SD (i.e. what is visible mirrors what is visible on the original).
SD card previously used in IPAQ so known to be functioning correctly.
sparkey
PostPosted: Thu Sep 15, 2005 10:30 pm    Post subject: Reply with quote
Hi there,
Did you format the card b4 you transfered ur files across to the card as other ppl were have trouble which sounds the same as you are having after formatted worked ok hope this helps
sparkey
PostPosted: Thu Sep 15, 2005 10:36 pm    Post subject: Reply with quote
Also is ur TTG new what version of windows or system you using.
Cos went i got mine the first time i connect TTG to computer which is running xp it saved a copy to my DOC'S the file was also named with the device number
lasitha
PostPosted: Fri Sep 16, 2005 2:51 pm    Post subject: Reply with quote
I had the same problem. I finally got it to work by attaching both TT GO and the card reader to the PC and coping from the TT GO directly into the card reader (i.e. without coping to the hard disk).
Oldboy
PostPosted: Fri Sep 16, 2005 7:31 pm    Post subject: Reply with quote
That's an interesting idea. It suggests that something was stopping read/writes to the Hard Drive.
Worth giving it a GO, if you're having problems.
Chigman
PostPosted: Fri Sep 16, 2005 8:54 pm    Post subject: Reply with quote
Yep,I had this same problem also and did try tom tom to card reader and vice versa,but still no good.This was with a sandisk 1 gigger and now it is going back.. Confused
smitty03
PostPosted: Fri Sep 16, 2005 10:02 pm    Post subject: Reply with quote
Thx for your suggestions guys. I tired you alternatives which still didn't work initially. Having looked a bit deeper into the file sizes copied over it was clear that a small amount of data had not come over from the original copy despite it looking the same in windows explorer. Now appear to have a working copy.
Next task-install safety camera POI's. Wish me luck!!
Thanks again.
motordoctor
PostPosted: Sat Sep 17, 2005 7:35 pm    Post subject: Reply with quote
just about to place post on tom tom go forum sounds like I have same problem as you and gone down same path so far trying to upgrade from 128mb to 512 card kept throwing it out with a cross on it on display any suggestions would be appreciated thanks Stuart Question Question Question
Oldboy
PostPosted: Sat Sep 17, 2005 8:18 pm    Post subject: Reply with quote
Have you been able to do a Full Backup to the Hard Drive?
Does the Backup Folder cantain roughly the same files and file sizes as the SD card?
When you Copy/Paste to the 512 SD card, once again are the files and file sizes the same?
If you Right Click the 512 card and select Properties, what information on Used, Free and Capacity do you get?
motordoctor
PostPosted: Sat Sep 17, 2005 9:05 pm    Post subject: Reply with quote
125,646,848 bytes on tom tom card but only 125,479,845 bytes copied onto new on and same onto pc hard drive, it seems to be missing some files somewhere Question Question Question
rkm_hm
PostPosted: Sat Sep 17, 2005 9:46 pm    Post subject: Reply with quote
Make sure that you use the option in Windows Explorer to view all files - including hidden files and system files. Otherwise, it will only copy the visible files, and miss the rest.
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
Oldboy
PostPosted: Sat Sep 17, 2005 11:33 pm    Post subject: Reply with quote
Have you done a file count to see if they tally?
Although I always use the 'Show Hidden Files and Folders', I have never seen them on any SD card I've used. If I hide them, I see exactly the same information.
motordoctor
PostPosted: Sat Sep 17, 2005 11:48 pm    Post subject: Reply with quote
tried to install hidden files as well tom tom still rejects card
