smitty03 Occasional Visitor
Posted: Thu Sep 15, 2005 9:19 pm Post subject: Back up of SD card-fall at first hurdle! |
TTG300 Viking 256mb SD (Japan) App 5.201 OS:908 Map v562
Apologies if answer already in forum but so much useful info I can't find it.
As recommended, trying to back up original SD onto Viking card before copying over Speed Camera files. Files appear to be a mirror image of those on original TTG card but when switching on TTG the infamous SD card with red cross appears.
I have tried doing back up via both the TTG and card reader but neither works.
Also, should I be able to get the SC files on the original card?
Help!
Thanks in advance. |
rugrat2 Regular Visitor
![](modules/Forums/images/avatars/4609311374435942342fdb.jpg)
Joined: Aug 14, 2005 Posts: 170 Location: Hull East Yorks
Posted: Thu Sep 15, 2005 9:41 pm Post subject: |
So are u saying that u cannot copy the files of your card via a card reader to your hard drive? |
Posted: Thu Sep 15, 2005 10:21 pm Post subject: |
No. Using both methods, the SD card appears to be holding all the right files following copy from original SD to HD then from HD to larger SD (i.e. what is visible mirrors what is visible on the original).
SD card previously used in IPAQ so known to be functioning correctly. |
sparkey Regular Visitor
![](modules/Forums/images/avatars/88590313145c9be79c9eda.gif)
Joined: Jul 01, 2005 Posts: 185 Location: Pembrokeshire
Posted: Thu Sep 15, 2005 10:30 pm Post subject: |
Hi there,
Did you format the card b4 you transfered ur files across to the card as other ppl were have trouble which sounds the same as you are having after formatted worked ok hope this helps |
Posted: Thu Sep 15, 2005 10:36 pm Post subject: |
Also is ur TTG new what version of windows or system you using.
Cos went i got mine the first time i connect TTG to computer which is running xp it saved a copy to my DOC'S the file was also named with the device number |
lasitha Occasional Visitor
Posted: Fri Sep 16, 2005 2:51 pm Post subject: |
I had the same problem. I finally got it to work by attaching both TT GO and the card reader to the PC and coping from the TT GO directly into the card reader (i.e. without coping to the hard disk). |
Oldboy Pocket GPS Moderator
Posted: Fri Sep 16, 2005 7:31 pm Post subject: |
lasitha wrote: | I had the same problem. I finally got it to work by attaching both TT GO and the card reader to the PC and coping from the TT GO directly into the card reader (i.e. without coping to the hard disk). |
That's an interesting idea. It suggests that something was stopping read/writes to the Hard Drive.
Worth giving it a GO, if you're having problems. _________________ Richard
Chigman Occasional Visitor
Posted: Fri Sep 16, 2005 8:54 pm Post subject: |
Yep,I had this same problem also and did try tom tom to card reader and vice versa,but still no good.This was with a sandisk 1 gigger and now it is going back.. ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
Posted: Fri Sep 16, 2005 10:02 pm Post subject: |
Thx for your suggestions guys. I tired you alternatives which still didn't work initially. Having looked a bit deeper into the file sizes copied over it was clear that a small amount of data had not come over from the original copy despite it looking the same in windows explorer. Now appear to have a working copy.
Next task-install safety camera POI's. Wish me luck!!
Thanks again. |
motordoctor Occasional Visitor
Joined: Oct 31, 2004 Posts: 8 Location: cleckheaton west yorkshire
Posted: Sat Sep 17, 2005 7:35 pm Post subject: |
just about to place post on tom tom go forum sounds like I have same problem as you and gone down same path so far trying to upgrade from 128mb to 512 card kept throwing it out with a cross on it on display any suggestions would be appreciated thanks Stuart ![Question](modules/Forums/images/smiles/icon_question.gif) |
Posted: Sat Sep 17, 2005 8:18 pm Post subject: |
motordoctor wrote: | just about to place post on tom tom go forum sounds like I have same problem as you and gone down same path so far trying to upgrade from 128mb to 512 card kept throwing it out with a cross on it on display any suggestions would be appreciated thanks Stuart ![Question](modules/Forums/images/smiles/icon_question.gif) |
Have you been able to do a Full Backup to the Hard Drive?
Does the Backup Folder cantain roughly the same files and file sizes as the SD card?
When you Copy/Paste to the 512 SD card, once again are the files and file sizes the same?
If you Right Click the 512 card and select Properties, what information on Used, Free and Capacity do you get? _________________ Richard
Posted: Sat Sep 17, 2005 9:05 pm Post subject: |
125,646,848 bytes on tom tom card but only 125,479,845 bytes copied onto new on and same onto pc hard drive, it seems to be missing some files somewhere ![Question](modules/Forums/images/smiles/icon_question.gif) |
rkm_hm Frequent Visitor
![](modules/Forums/images/avatars/gallery/web.jpg)
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Posted: Sat Sep 17, 2005 9:46 pm Post subject: |
motordoctor wrote: | 125,646,848 bytes on tom tom card but only 125,479,845 bytes copied onto new on and same onto pc hard drive, it seems to be missing some files somewhere ![Question](modules/Forums/images/smiles/icon_question.gif) |
Make sure that you use the option in Windows Explorer to view all files - including hidden files and system files. Otherwise, it will only copy the visible files, and miss the rest. _________________ Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire |
Posted: Sat Sep 17, 2005 11:33 pm Post subject: |
motordoctor wrote: | it seems to be missing some files somewhere ![Question](modules/Forums/images/smiles/icon_question.gif) |
Have you done a file count to see if they tally?
Although I always use the 'Show Hidden Files and Folders', I have never seen them on any SD card I've used. If I hide them, I see exactly the same information. _________________ Richard
Posted: Sat Sep 17, 2005 11:48 pm Post subject: |
tried to install hidden files as well tom tom still rejects card |
