Pocket GPS World :: View topic - Speed readout
Speed readout
iuw
PostPosted: Wed Sep 14, 2005 1:04 am    Post subject: Speed readout Reply with quote
Hi All
Before I bought my TT Classic, some while ago, I had an Origin B2 which, if set in the menu, could display a large speed readout, easily read from most locations.
Does anyone know if the TomTom Classic can be made to perform this trick?
I found it useful to have a large readout as a backup speedo.
Roger
Unplugged
PostPosted: Wed Sep 14, 2005 3:10 am    Post subject: Reply with quote
Im not sure on the Classic but on the Go300 By Default theres only two one you can enable on the main screen which is showed at all times and I usually find this sufficient.
Change Preferences > Status Bar Prefrences and make sure the SPEED option. or by clicking the status bar from the main screen and where it says the number of Satalites touch that and it will give you the reading there.
Other than that a Full screen readout no although somebody might be able to make an app for it.
TM
PostPosted: Wed Sep 14, 2005 9:29 am    Post subject: Reply with quote
I think, if you turn off the map display the speed is displayed in the middle of a blue screen.
iuw
PostPosted: Thu Sep 15, 2005 8:55 pm    Post subject: Reply with quote
Thanks Folks
TM...we must be "neighbours"...Located in Stroud
Roger
TM
PostPosted: Fri Sep 16, 2005 10:47 am    Post subject: Reply with quote
iuw wrote:
Thanks Folks
Roger
8)
Luffer
PostPosted: Fri Sep 16, 2005 5:17 pm    Post subject: Reply with quote
Not on my 300, it gives you a graphical representation of your next manouvere, with the usual data at the bottom
