Pocket GPS World :: View topic - 5450 to bt
5450 to bt
westentertainer
PostPosted: Tue Sep 06, 2005 6:18 pm    Post subject: 5450 to bt Reply with quote
can anyone help i am having massive problems trying to conect my ipaq5450 to a bt bluetooth receiver can anyone who has done this before please give me some advice many thanks
t_rifles
PostPosted: Tue Sep 06, 2005 9:03 pm    Post subject: Reply with quote
I had problems with mine at the best I get now is to confirm connection each time I start TT
Using TT5.10
Turn BT on
Pair the bluetooth GPS and IPAQ in BT Manager (paired devices/add)
Start TT
Turn on GPS
Says No GPS Device
In preferences /showGPS status/configure, choose other BT GPS
Press continue
Select first BT Serial Port in list (port8)
Should then be ok.
Each time I start TT it then finds no gps, goes to BT Console where double click TT GPS, wait 5 seconds and ok.
Terminator
PostPosted: Tue Sep 06, 2005 9:58 pm    Post subject: Reply with quote
What version of Windows are you using on the 5450 ? I'm using the 2003 upgrade and there is a bluetooth driver update for it which has solved all my bluetooth problems.
I paired the receiver with the iPaq and then connect using BT Serial Port 8.
t_rifles: the "no gps device" issue is a *cough* feature, it should say "no gps fix" if you leave it on the screen for 10-15 seconds it will get the fix and work ok without the need to go into the configuration screen.
westentertainer
PostPosted: Wed Sep 07, 2005 12:10 am    Post subject: Reply with quote
is it the drivers that came with the reciver??
madasaman
PostPosted: Wed Sep 07, 2005 8:55 am    Post subject: Reply with quote
try the page on TomTom, go to product support and look at the question, How to manually configure TomTom NAVIGATOR 5 for Bluetooth GPS receivers. According to tomtom you should be using com 8, but all the instructions are there.
http://www.tomtom.com/support/rightnow.php?p_prods=62%2C0&p_pv=1.62%3B2.u0&p_search_type=answers.search_fnl&p_new_search=1&p_prod_lvl1=62&p_search_type=&p_search_text=gps
madasaman
westentertainer
PostPosted: Wed Sep 07, 2005 3:04 pm    Post subject: Reply with quote
strange it conected with..other nmea.. as info on tomtom site BUT only conected once as a blue tooth console kept poping up ,even when itried to conect to wired reciever this console kept poimg up ,so i had to wipe and reinstall tom tom.... fed up now
Terminator
PostPosted: Wed Sep 07, 2005 8:59 pm    Post subject: Reply with quote
It's an update from HP for the iPaq if your running PC2003 - Link
Does the reciever show up OK in the Bluetooth Manager and can you get a connection to it from there ?
westentertainer
PostPosted: Thu Sep 08, 2005 3:24 pm    Post subject: Reply with quote
conecting ok now ,only one anoyin fault when you start tt5 it shows you a bluetooth console and you have to select bt receiver from ther e many thanks
uk89camaro
PostPosted: Fri Sep 09, 2005 10:29 am    Post subject: Reply with quote
Same here, although for me it was the same with TT3. It would be useful if TT5 started up the bluetooth connection, in the same way TT5 now closes the connection on exit.
Tom Tom 1005 v2 World, Garmin Dakota 20, IPhone 4S
Talkingbollox
PostPosted: Fri Sep 09, 2005 12:21 pm    Post subject: Reply with quote
It would be useful if TT5 started up the bluetooth connection.....
On my setup TTN 5.10 does start and close the bluetooth connection. I have TT5 assigned to a hardware button and one press gets me going if I'm using my BT receiver.
uk89camaro
PostPosted: Fri Sep 09, 2005 6:11 pm    Post subject: Reply with quote
I haven't tried that. Do you build up the applications that need to be started, like a schedule....turn on bluetooth/connect to device/start TT5..?
Talkingbollox
PostPosted: Fri Sep 09, 2005 10:28 pm    Post subject: Reply with quote
Nope. As long as you've already set up the bluetooth receiver in TTN 5.10, it remembers the configuration the next time. It will shut down bluetooth. Next time you turn on TT5 by pressing the hardware button, it opens up TT5, turn on bluetooth, and connect to the receiver.
As I said, 1 press of a button and you're away.....
22.062 (12 Jun 24)
