sparkey Regular Visitor
![](modules/Forums/images/avatars/88590313145c9be79c9eda.gif)
Joined: Jul 01, 2005 Posts: 185 Location: Pembrokeshire
Posted: Mon Aug 29, 2005 7:02 pm Post subject: New updates for cameras |
Hi sorry for being a bit thick i've just downloaded the new update for cameras I know I have to put the ov2 bmp files in, which is in one folder
BUT I also see a new folder called speed zone with ov2 files in it, do I put them into map of britain as well or are they included in the other ov2 bmp files
BTW i've got a TTG 300 |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Mon Aug 29, 2005 8:03 pm Post subject: |
Depends what you want to see...
There's a single file with all the cameras in it.
There's the ov2 bmp file with the same cameras in it, but split by type.
The the Speed Zoned set which splits them further and tells you the speed limit. If you use these you need the redlight, specs and temp files from the ov2 bmp folder for a complete set. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Mon Aug 29, 2005 9:03 pm Post subject: |
Thanks for the reply :D |
golf747 Occasional Visitor
![](modules/Forums/images/avatars/gallery/089.gif)
Posted: Tue Aug 30, 2005 11:05 am Post subject: |
Further to this, I have the latest camera database installed and working, however when the next update is downloaded, presumably it will reinstal any individual cameras that are I have deleted. ? I have taken 3 out in my local area as 2 were temp ones in motorway roadworks and the other one has never be there, just the usual signs |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Tue Aug 30, 2005 11:44 am Post subject: |
Have you reported them? _________________ Richard
Posted: Tue Sep 06, 2005 8:43 am Post subject: |
I haven't reported them yet. What is the best way, can I give the database/camera number ?
Going back to the original question downloading the latest release would reinstall the previously deleted cameras, unless off course they have been deleted from your main list? |
DeeSee Lifetime Member
Posted: Tue Sep 06, 2005 11:26 am Post subject: |
Putting the latest database on will reinstall the cameras that you deleted.
Until you and the rest of us inform them of changes errors will remain: PocketGPS are not psychic.
If you browse the map and click on the relevant cameras you will get their names. Post these to Cameras@PocketGPSworld.com.
Please send them any changes at least 10 days before the end of the month to give them time to update the files.
You may also like to pick up Scaredycats "Quickam" application which allows you to enter new cameras with two presses of the screen
http://www.automated.it/ttg-apps.html
Find the "More apps for your Go" (or something like that) thread for info on this. |
Andy_P Pocket GPS Moderator
Posted: Tue Sep 06, 2005 7:14 pm Post subject: |
Whether you use scaredycat's Quickam or do it manually, I find the easiest way to send in updates is to save any new cameras you find (with a name that includes the speed limit in it somewhere) into a seperate POI category (I call mine "new cams" and have a yellow warning triangle as the icon) and then just send the "newcams.ov2" file to Cameras@PocketGPSWorld.com as an email attachment once a month.
Any cameras which have gone can be marked as POIs in the same way., and anything that needs a bit of description (like "its a red light cam not a speed cam and the limit is 40 not 50") or can be mentioned in the email too.
At the end of the month, when you download the new database, you get that warm feeling of pride when you check all your updates are there :D
Then, just delete everything from your "newcams" POI and start afresh.
Sad I know, but I find camera hunting quite addictive! 8O |
