rsutcliffe Occasional Visitor
Posted: Sat Sep 03, 2005 11:14 am Post subject: |
hogbreath - let me know if you still get this message after reloading. |
hogbreath Regular Visitor
Joined: Feb 07, 2004 Posts: 139 Location: Hillingdon, Middx
Posted: Sat Sep 03, 2005 11:44 am Post subject: |
Ok
It's loaded now, went and did an OTN update and got an error message - something about a proxy server not found. OTN has now disappeared from the system tray. All that was left in My Doc's is a bmp file only.
Any ideas?
Pete |
Posted: Sat Sep 03, 2005 11:57 am Post subject: |
Got two error messages after a reboot:-
1/ The remote server returned an error (403) forbidden
2/ An unhanlded exception has occurred....cannot access a disposed object named "formToast".
It's not looking too good!
Pete |
Posted: Sat Sep 03, 2005 12:56 pm Post subject: |
Currently OTN does not support proxy servers - I am working on this now! |
Paul-m Regular Visitor
Posted: Sat Sep 03, 2005 1:41 pm Post subject: |
This may seem like a bit of a simple solution...but..
I have an old PC that i sometimes play around with Linux on. One of the things i do is make it visible to the web as a personal webserver.
Im sure it wouldnt be too difiicult to drag across the traffic...OV2 file so i could retireve it when im mobile and using either dialup or GPRS connectivity.
Im using a free dynamic dns service as part of the Netgear router package so i dont need to worry about my IP address.
any thoughts?
Paul |
oka97 Occasional Visitor
Posted: Sat Sep 03, 2005 4:43 pm Post subject: |
Hi I get
"underlying connection was closed: Unable to connect to remote server"
I noticed there are 2 XML config files in the app directory, which one is actually used? What should it look like.
Thanks |
Posted: Sat Sep 03, 2005 4:51 pm Post subject: |
I figured out which of the xml config files are used, and here is the content which I'm sure is wrong? The trafficfeeds key looks a bit odd! :-)
<?xml version="1.0" encoding="utf-8"?>
<Configuration xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<AppSettings>
<Key Name="AutoSync" Value="True" />
<Key Name="DeviceSyncPath" Value="\My Documents\" />
<Key Name="UpdateInterval" Value="18000" />
<Key Name="UpdateNotify" Value="False" />
</AppSettings>
<TrafficFeeds />
</Configuration> |
Posted: Sat Sep 03, 2005 4:53 pm Post subject: |
Could someone have a look at their config xml file please? |
Posted: Sat Sep 03, 2005 7:14 pm Post subject: |
oka97 - travelfeeds.opml holds the URL's for all the TPEG travel feeds.
The config file simply holds application settings. The travelfeeds key is intentionally empty, as this was going to be used for holding custom feed url's. As no-one but the Beeb is publishing these at the moment it's redundant. |
Posted: Sat Sep 03, 2005 7:19 pm Post subject: |
NEW VERSION!!!
Version 0.2 is ready now
Improvements include:
• Improved error handling.
• Improved configuration handling (no more restarting the utility to reflect changes in the options window).
• Updated receipt notification & about window graphics.
• Updated help file.
• Added secondary file synchronisation location for TomTom Go users.
• Added XML logging for recording bad travel feeds.
• Added [experimental] proxy server support. |
Posted: Sat Sep 03, 2005 7:41 pm Post subject: |
Hi thanks for your kind replies.
So where do we get the latest version? Same place? 8) |
Posted: Sat Sep 03, 2005 7:45 pm Post subject: |
I've posted it to PocketGpsWorld, but if you want me to mail you it in the meantime send an email to otn@nospam.delphi-dolphin.com - removing the obvious bit! |
Posted: Sat Sep 03, 2005 7:59 pm Post subject: |
I cut down the opml file to this but still received the same error, the XML file in the HTTP location's definitely there so I'm totally stumped as to why this isn't working
<?xml version="1.0" encoding="ISO-8859-1" standalone="yes"?>
<opml version="1.1">
<head>
<title>BBC Travel News TPEGML Feeds</title>
<dateCreated>2005-05-13 10:30:29</dateCreated>
</head>
<body>
<outline text="Central London" title="Central London" xmlUrl="http://www.bbc.co.uk/travelnews/tpeg/en/local/rtm/londoncentral_tpeg.xml" type="rss" language="en" htmlUrl="http://www.bbc.co.uk/travelnews/local/london_central.shtml" />
</body>
</opml> |
Posted: Sat Sep 03, 2005 8:15 pm Post subject: |
Are you behind a proxy server?
If not you'll need to wait until the new version is posted on here as it produces better error logs that allow me to establish exactly what went wrong. |
Posted: Sat Sep 03, 2005 8:35 pm Post subject: |
I have a direct connection to my adsl internet, no firewall, nothing!
Rather odd. Could you email the latest version to me if u have time?
I mailed the address u provided (minus the no spam) but it bounced!
okahmed@ g mail.com |
