Pocket GPS World :: View topic - Off Line Traffic News - Traffic POIs for TomTom
Goto page Previous  1, 2, 3, 4 ... 11, 12, 13  Next
alfie
PostPosted: Thu Sep 01, 2005 11:18 am    Post subject: Proxy Server config. Reply with quote
Richard, great program, but I am having a problem getting the updates as I connect to the internet via a proxy server. Is it possible to configure this in some way, if not please can you add to the "wish list".
Thanks & keep up the good work.
SharpEye
PostPosted: Thu Sep 01, 2005 4:12 pm    Post subject: Initial Observations Reply with quote
Just downloaded OTN and installed onto an XP Pro machine linking via ActiveSync to an HP2210 running TT3.
On initial install I couldn't find a folder that OTN installed to under start-programs. I was not asked to reboot, but I did to see if OTN appeared - and it did, in the system tray.
I have since sussed that it resides in the startup folder.
I have set it to automatically update the great britain folder. Unfortunately I have not yet got to update. So far when it trys to retrieve it has given a 404 error and an xml error on line (can't remember which line, sorry).
After each time OTN tells me that an update has been received - but it hasn't cos it failed. Perhaps a little error trapping is needed here.
I have looked back at the SD car and the ovl/bmp pair of files have not been created.
Regards
SharpEye
SharpEye
PostPosted: Thu Sep 01, 2005 4:23 pm    Post subject: XML Error Reply with quote
I have managed to get another aml error when OTN tries to retrieve an update. It said....
There is an error in the xml document (1,44)
Then the task bar icon disappeared
SharpEye
SharpEye
PostPosted: Thu Sep 01, 2005 4:50 pm    Post subject: Reply with quote
Just got a dialogue with the title Miccrosoft .net framework which said...
----start of dialogue-----
An unhandled exception has occured in a component in your application. CLick continue and application will ignore this error and attempt to continue.
Object Reference notset to an instance of an object
And the details button revealed
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at OfflineTrafficNews.ApplicationMain.menuUpdate_Click(Object sender, EventArgs e)
at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
at System.Windows.Forms.MenuItemData.Execute()
at System.Windows.Forms.Command.Invoke()
at System.Windows.Forms.NotifyIcon.WndProc(Message& msg)
at System.Windows.Forms.NotifyIconNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
OfflineTrafficNews
Assembly Version: 1.0.2068.23970
Win32 Version: 1.0.2068.23970
CodeBase: file:///C:/program%20files/Richard%20Sutcliffe/OfflineTrafficNewsSetup/OfflineTrafficNews.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
5df4qhwe
Assembly Version: 0.0.0.0
njqqyxb2
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
------end of dialogue-------
CLicking on continue gave another dialogue with no title and said The remote server returned an error:(404) Not found 404
The cause of the first dialogue was.......I got the xml error due to the proxy server stopping OTN in mid update, this closed OTN. I restarted OTN and it started to update. From the proxy server I could see that it had connected to bbc trave and was trying to download the bedfordshire portion, but once again the proxy seemed to not allow otn to download any others and hence the above dialogue appeared.
Hope it helps
SharpEye
SharpEye
PostPosted: Thu Sep 01, 2005 5:29 pm    Post subject: Harrah! (Almost) Reply with quote
OTN updated ok with the ovl/bmp pair of files found under My Documents. :D However it is still not transferring over to the PPC.
Confused
OTN did not give any errors, if I look under options it is showing the correct path to the map folder and the automatically update map overlay check box is ticked.
What say you
rsutcliffe
PostPosted: Thu Sep 01, 2005 8:23 pm    Post subject: Offline Traffic News Reply with quote
Sharpeye - sorry to hear of your issues. I've already added more error trapping around the feed retrieval and the next update will include this.
The XML issue has been seen infrequently before and seems to be a problem with the feed (or server). As soon as I can recreate this in debug mode I will attempt to fix. I may try adding some functionality that stores the offending XML document so affected users can provide me with useful additional debuggung info.
alfie - I forgot all about proxy servers! I will endevour to fix this, however I will be unable to test as I don't use the net in this way.
Paul-m
PostPosted: Thu Sep 01, 2005 8:24 pm    Post subject: Reply with quote
I have just installed and got the same problem. So i manually copied the files from MyDocuments to the SD card Map directory.
I then shutdown OTN and restarted it making sure the options pointed to the correct directory. This time it worked perfectly. It even enabled the POI in TomTom 5. excellent
Now for some requests.
How about making OTN start updating automatically when the PPC is connected? i didnt see that happen unless i missed something. It would be ideal to have it in the Activesync folder as a program....
nealjane
PostPosted: Thu Sep 01, 2005 10:07 pm    Post subject: Reply with quote
Im also having a bit of bother having installed this fantastic bit of software -
when I click on the icon and click on 'options' I get an error message as the prevous reply microsoft NET....
and then under details -
System.DllNotFoundException: Unable to load DLL (rapi.dll).
at OpenNETCF.Desktop.Communication.RAPI.CeGetLastError()
at OpenNETCF.Desktop.Communication.RAPIException..ctor(String Message)
at OpenNETCF.Desktop.Communication.ActiveSync..ctor()
at OpenNETCF.Desktop.Communication.RAPI..ctor()
at OfflineTrafficNews.formOptions..ctor()
at OfflineTrafficNews.ApplicationMain.menuOptions_Click(Object sender, EventArgs e)
mscorlib
OfflineTrafficNews
CodeBase: file:///C:/Program%20Files/OfflineTrafficNewsSetup/OfflineTrafficNews.exe
System
System.Drawing
System.Xml
c2bkw0pq
95xlp6_n
Assembly Version: 2.8.1584.19264
Win32 Version: 2.8.1584.19264
CodeBase: file:///C:/Program%20Files/OfflineTrafficNewsSetup/OpenNETCF.Desktop.Communication.DLL
enabled.
For example:
<configuration>
</configuration>
I dont have a windows PPC - so no active sync installed, im intending on using it with my palm tomtom - but I cant change the region to my area at the moment!
any advice would be appreciated.
rsutcliffe
PostPosted: Thu Sep 01, 2005 10:28 pm    Post subject: Offline Traffic News Reply with quote
nealjane - The PocketPC synchronising is based on a DLL that comes with ActiveSync, and this is whats causing your issue here.
I clearly need to find a better way to detect whether this is installed. I will try and find a fix for this but it may not be in the next version.
eversonl
PostPosted: Fri Sep 02, 2005 5:11 pm    Post subject: Re: Offline Traffic News Reply with quote
happy to test as I also use proxy while at work
molchew
PostPosted: Fri Sep 02, 2005 9:14 pm    Post subject: Server User Reply with quote
I will also be able to test the Proxy server version.
hogbreath
PostPosted: Sat Sep 03, 2005 12:08 am    Post subject: Reply with quote
Unable to get past "you need to intstall .NET Framework v1.1.4322 - I did or think I have but still the message appears?
Pete
MS WinXP Pro
Version 2002
SP2
rsutcliffe
PostPosted: Sat Sep 03, 2005 10:01 am    Post subject: Reply with quote
hogbreath - OTN is written in C#, which requires the .Net framework. The message you are seeing means this is probably not already installed on your PC.
The .Net framework can be downloaded directly from the Microsoft website via Windows Update or on the following link:
http://www.microsoft.com/downloads/details.aspx?FamilyID=262d25e3-f589-4842-8157-034d1e7cf3a3&displaylang=en
hogbreath
PostPosted: Sat Sep 03, 2005 10:15 am    Post subject: Reply with quote
Hi rsutcliffe
Did'nt make myself clear, yes have loaded the software, but still got the message.
Is there some way to check what ver of .NET Framework I have?
It should not be this difficult
Pete Smile
hogbreath
PostPosted: Sat Sep 03, 2005 10:35 am    Post subject: Reply with quote
Went & checked via control panel>add/remove programs.....for the ver of .NET Framework installed, guess what none there!
Back now to reload, guess this should sort out the probelm.
Pete
Page 3 of 13
22.062 (12 Jun 24)
