Pocket GPS World :: View topic - heat reflective windscreens in new cars
worthingsaxovtr
PostPosted: Thu Sep 01, 2005 3:02 pm    Post subject: heat reflective windscreens in new cars Reply with quote
I have been told that at the top of the window just infront of the rear view mirror there is no heat reflective material on the wind screen
is this true, has anybody tried it
i have a citreon xsara 2002
cheers
jimbokb
PostPosted: Thu Sep 01, 2005 5:45 pm    Post subject: Reply with quote
If you are having problems with signal strength don't bother trying to relocate your unit, just get yourself an external aerial. The increase in the amount of satellites you get is superb. the aerial is only a flat disc that sits on your roof (or wherever you care to put it). On the downside it costs around £40 but is a great investment.
TTG 300,External Aerial
1Gig Viking SD, 512 Viking SD(Backup)Nokia 6680 (o2), 512 MMC
Map Great Britain v 562 App v 6.150 , GPS v 1.21 Boot 4.29, OS:1221
dill
PostPosted: Thu Sep 01, 2005 11:14 pm    Post subject: Reply with quote
Where from, and dont you think that after spending hundreds of pounds an external aerial should be included in the box, the bloody thing is supposed to be plug in and go, thats why its called a Go, if you havent got the correct screen its no Go.
Wake up.
chris_w
PostPosted: Fri Sep 02, 2005 2:34 pm    Post subject: Reply with quote
Totally agree - best thng I bought for mine, you can get a signal anywhere.
P.S I do hope you are awake when you're driving 8O I've heard it can be very messy if you're asleep..... Laughing
Thanks,
Chris
Skippy
PostPosted: Fri Sep 02, 2005 2:40 pm    Post subject: Re: heat reflective windscreens in new cars Reply with quote
Yes, it is true. I tried it on a Renault Laguna that I hired for a while.
Have a close look at the outside of the window. You can see that the heat reflective coating has a bluish tinge to it when viewed at the right angle in bright sunlight. Now have a look at the rear view mirror, you often see that there is a dark tinted patch around it, this is because there is no heat reflecting coating on this area. You can often see that there is no bluish tinge to the reflection in this area.
Gone fishing!
jimbokb
PostPosted: Fri Sep 02, 2005 5:53 pm    Post subject: Reply with quote
dill , yes after spending a small fortune it should work out of the box and it does, but hey it just works so much better with an External Aerial. :P
fatmanscoop
PostPosted: Fri Sep 02, 2005 10:43 pm    Post subject: Reply with quote
i have a laguna which as a reflective windscreen well here is my ttg with my external antenna. sorry its a little blur .
so im my opinion for say £50 its money well spent
Garmin xt mobile
Nokia N96
Liverpool F.C rocks
satsam
PostPosted: Fri Sep 02, 2005 11:20 pm    Post subject: external antenna Reply with quote
Hi. If I buy an external antenna does this mean that the TTG mount will have to be left in place when I leave the car as for as far as I can see the antenna cable is fitted to the base. This would alert a theif to the Satnav in the car.
cheers for your input. Question
jimbokb
PostPosted: Fri Sep 02, 2005 11:31 pm    Post subject: Reply with quote
No all that changes is the bottom of the screen mount. you can still take it with you
