AC Occasional Visitor
Posted: Thu Sep 01, 2005 7:41 pm Post subject: POi Warner voice warnings |
I wonder if you could help. I had a safety camera warning on my tom tom camera warnings, which gave a verbal message saying "warning , danger zone ahead." My pc has just been replaced and I cannot find this programme. I wonder if you could help?
I am using the camera database on TTN 5 on an IPAQ 3900 series. |
Posted: Thu Sep 01, 2005 9:38 pm Post subject: |
would be grateful if anyone knows the answer it's driving me mad! |
Oldboy Pocket GPS Moderator
Posted: Thu Sep 01, 2005 10:15 pm Post subject: |
Did you mean this - http://www.navigating.de/Home_en/ _________________ Richard
Posted: Thu Sep 01, 2005 10:17 pm Post subject: |
that is the one I am using, but I can't find the voices for the ipaq version anymore, do you know exactly what I should do to get it back, at the moment all I have to choose from are beeps etc not a voice with the above message. would be grateful if you know |
Posted: Thu Sep 01, 2005 10:26 pm Post subject: |
I understood that POIWarner had the voice files built in.
If you want the voices for this sites cameras and TT5 you mean the data.chk file. This can be downloaded from http://www.pocketgpsworld.com/tomtom-poi-alerts.php _________________ Richard
Posted: Thu Sep 01, 2005 11:29 pm Post subject: |
Hi Richard,
Have taken a look at the link but sorry to say still struggling! I have Tom Tom Navigator 5 and can't find out which one to use. Can you help!? Can't find exactly the message I had previously either, do you know of it. |
Posted: Fri Sep 02, 2005 6:46 am Post subject: |
The data.chk for yours is I believe the 4890.
The actual instruction you give, I believe, came from/with POIWarner, but it might have come from a custom voice set that someone else may have created. _________________ Richard
Posted: Fri Sep 02, 2005 6:33 pm Post subject: |
tried that, followed it through step by step, but still have the original sounds, really odd! |
Posted: Fri Sep 02, 2005 7:58 pm Post subject: |
Did you put the data.chk file in My Device\Program Files\Navigator? _________________ Richard
Posted: Fri Sep 02, 2005 9:31 pm Post subject: |
Put the file under the tom tom directory which is where the original was , I renamed the original and changed the name of the new one to what it suggested |
Posted: Sat Sep 03, 2005 8:27 am Post subject: |
Which Directory? On the SD card or in memory. _________________ Richard
Posted: Sat Sep 03, 2005 9:31 am Post subject: |
In the memory, the only file I can find on the sd card are the maps |
Posted: Sat Sep 03, 2005 11:37 am Post subject: |
Have you any other data.chk files, either in memory or on SD card?
What did you rename the original to? _________________ Richard
Posted: Sat Sep 03, 2005 12:03 pm Post subject: |
thanks for coming back . the original is called data05.chk and I renamed this to auddata05.chk I can't find any others anywhere. I left the renamed one there and renamed the new one to data.chk |
Posted: Sat Sep 03, 2005 4:38 pm Post subject: |
Data05.chk file is Janes directions voice.
There are 2 types of voice files. The POI warning file is called data.chk and the voice direction files are called dataxx.chk. A different number is a different language file.
If you do a Explorer Search, on the PDA, for *.chk, it should turn up all the data.chk files you have. You will need to search My Device, not the SD card.
Also you will have to rename auddata05.chk back to data05.chk to get Jane's directions. _________________ Richard
