Pocket GPS World :: View topic - PoiEdit map calibration
gripp
PostPosted: Thu Sep 01, 2005 3:22 pm    Post subject: PoiEdit map calibration Reply with quote
Does anyone know the map cabibration coordinates for the UK map that comes with PoiEdit? I'm talking about this one:
http://www.btinternet.com/~gripp/webpics/UK_web.jpg
The FAQ says "it's not very dificult", but trying to estimate the coordinates for a point in the middle of the English Channel off Land's End is not easy!
Or could some kind person let me have a UK map, plus coordinates and corresponding .inf file?
Thanks,
Geoff.
Nokia E65 & TT Nav6
Donald
PostPosted: Thu Sep 01, 2005 4:59 pm    Post subject: Re: PoiEdit map calibration Reply with quote
Thanks,
Geoff.
This is one of the minor irritations of the new method of map calibration! It has made it much more difficult to do it!
However, taking a look at that map and using Autoroute 2004, the nearest I can make it for each edge (Excluding the thin white border which must be cropped out because it will intrude...)
Top edge: 59.44679
Right edge: 2.19093
Bottom edge: 49.93387
Left edge: -5.71816
Axim X50 & TT5, Arkon CM820 powered mount with built in sirf2 gps
Axim 5 sans GPS Rx
Ford Focus 2L Ghia, Wife, kids, dog, cats, mortgage, bank manager & taxman to support, debts, windows need painting - (I cut the grass! - its rained - it needs
gripp
PostPosted: Thu Sep 01, 2005 5:30 pm    Post subject: Reply with quote
Donald,
Thanks for that - the map now appears and no longer says it must be calibrated.
However, if I load a GATSO file there are no indications on the map as to where the GATSOs (or any POIs) are - I'm sure in previous version the map was peppered with little red pins, or is my memory playing tricks?
I also have a program called POIViewSE which does indicate POIs on a UK map, but the map is just an outline of the UK coloured yellow with no details apart from a few roads.
Nokia E65 & TT Nav6
Donald
PostPosted: Thu Sep 01, 2005 8:49 pm    Post subject: Reply with quote
gripp wrote:
Donald,
Can't comment on that - All I have ever seen is the one poi that is highlighted in the list. as you scroll down through the list, the location of that POI is shown on the map.
If you have Autoroute, you can use PoiEdit to convert to a suitable file type so that you can 'import data' into Autoroute. Then All POIs will appear at once as PushPins.
Regards
Axim 5 sans GPS Rx
22.055 (29 May 24)
