gugi_sat Occasional Visitor
![](modules/Forums/images/avatars/gallery/praying_hands.jpg)
Posted: Tue Aug 16, 2005 9:41 pm Post subject: TOMTOM5 does not start........ |
Hi to u all
I have a problem
i have tomtom 5 installed it worked fine for few weeks now its not starting
when i start tomtom only BUSY circle comes up . thats it and after some time i have to restart my XDA
i have tried to uninstall and removing all the reg keys form regestry as well and then install it again
still getting the same problem
i just do not understand y this doing so
plz can any one help me ???
Regards
GUGI |
hogbreath Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_matrix_016.jpg)
Joined: Feb 07, 2004 Posts: 139 Location: Hillingdon, Middx
Posted: Tue Aug 16, 2005 9:59 pm Post subject: |
GUGI
If all was working ok, & now not, could it be where you have the maps loaded, in other words a problem with your sd card, what happens if the sd card is removed, does the busy circle still show or do you get can't find maps error messge?
Pete |
Posted: Tue Aug 16, 2005 10:07 pm Post subject: |
hi hogbreath
thanx for reply
yeah when i remove my sd card the busy circle stay on the screen and then my xda hangs
then i have to restart it
Regards
GUGI |
Posted: Tue Aug 16, 2005 10:10 pm Post subject: |
Where have you loaded tt5 in main memory or on the sd card?
Pete |
Posted: Tue Aug 16, 2005 10:16 pm Post subject: |
hi Pete
all the maps is on sd card
only the tomtom navigator.exe file in pf\navigator\
thats only i can see there are some other folder one in my documents
other one in My Device called Tomtom
Regards
Gugi |
Posted: Tue Aug 16, 2005 10:19 pm Post subject: |
Just a thought, you may have lost the link to the tt5 program, try starting tt5 from within the folder that ttnstart.exe is located in, think it's in a folder called tomtom, sorry don't have tt5 loaded at present & my tt3 setup is all on the cf card so will be a different layout to yours.
Pete |
Posted: Tue Aug 16, 2005 10:26 pm Post subject: |
nope
tried that ( tryed to start the program form PF\Navigator\tomtom Navigator.exe)
no luck same old busy circle come up that's it
Regards
Gugi |
Posted: Tue Aug 16, 2005 10:33 pm Post subject: |
I'm running out of suggestions, the card may still be a prob, are you able to load tt5 to main memory - this would at least eliminate the card.
What do you think or have you done this already?
Hard reset first!!!
Pete |
Posted: Tue Aug 16, 2005 10:37 pm Post subject: |
hi Pete
i don't have that much memory on my device on 50 MB left but these maps need i think more than that
i might be a sd card prob if it is there any way to solve it ?
other thing i can read and write on the sd card with no problems because i have vedio and songs on my sd card its working fine also i tried to save files on it thats saved ok as well
Regards
Gugi |
Posted: Tue Aug 16, 2005 10:41 pm Post subject: |
You don't have to load the maps into main memory, they can be left on the sd, the actual mem needed for just tt5 programs is around 2mb, may be less.
I'm trying to suggest an alternative setup to get tt5 going.
Pete |
Posted: Tue Aug 16, 2005 10:43 pm Post subject: |
Hi Pete
actual program is in PF\Navigator which is call Tomtom Navigator.exe
which is 1.59MB
Regards
Gugi |
Posted: Tue Aug 16, 2005 10:46 pm Post subject: |
PF is Program Files |
Posted: Tue Aug 16, 2005 10:49 pm Post subject: |
sorry should have read your posts, may be worth loading tt5 onto the sd card, instead of in main memory then, or.....
Alternatively I would be tempted to wipe everything clean and start fresh, no other progs loaded just tt5?
Pete |
Posted: Tue Aug 16, 2005 10:55 pm Post subject: |
i copied tomtom navigator.exe file to sd card
got the same problem ( busy circle)
I don't want to hard reset my device got to much data and programs( which i lost the cab files now)
Regards
Gugi |
Posted: Tue Aug 16, 2005 11:00 pm Post subject: |
Has tt5 got enough mem to run on your xda?
How much free mem is showing?
Pete |
