Pocket GPS World :: View topic - Intermittent startup TTN 5
babelfish
PostPosted: Tue Aug 09, 2005 9:30 pm    Post subject: Intermittent startup TTN 5 Reply with quote
Ello..
Just upgraded my TTN3 to TTN5....
When I touch the Navigator icon the program always freezes, with the small icon showing at the bottom right, soft reset needed.
But.. if I load up another program, for example Memory Map, which is located on the same Kingston 1GB SD card, exit, then execute Tom Tom, it loads up fine..! Just plain weird.
Can anyone suggest any workaround for this problem..?
Thank You.
berghaus
PostPosted: Tue Aug 09, 2005 11:41 pm    Post subject: Reply with quote
When you exit M/Map be sure to exit via MENU EXIT which is in the bottom left of M/Map screen, otherwise M/Map will still be running in the back ground making TTom run like SH**.
I am sure that this will solve your problem. :D
MIO 168 + MICROMAXX MDPPC 150 WITH MEDION FIRMWARE UPGRADE (A MUST FOR TTN5)
TTN5
Memory Map 2004 1:50000 & 1:25000 + AERIAL ALL UK (FANTASTIC)
Mountain Biking (OFF ROAD)
Hiking
babelfish
PostPosted: Thu Aug 11, 2005 8:46 pm    Post subject: "Proper Format" Reply with quote
Thanks berghaus for yout suggestions.... but I assure you I always exited Memory Map correctly....
The Only way I managed to get TTN5 to statup up 100% of the time was to format the SD with an external application...
Pocket Mechanic gives you a plethora of formatting options... I formatted the card with a FAT16 4K cluster option.
Tom Tom loads & restarts 100% now....
Hope this helps others...
22.062 (12 Jun 24)
