Pocket GPS World :: View topic - Lowpower Mode
Lowpower Mode
wjrs5
PostPosted: Sat Jul 17, 2004 7:13 am    Post subject: Lowpower Mode Reply with quote
Does anybody know what extra battery life you will get on the Emtac if you switch it into Low Power mode using the CruxView utility? Also, on this screen in Cruxview, what is the meaning of "On Time (ms)"?
lbendlin
PostPosted: Sat Jul 17, 2004 4:12 pm    Post subject: Reply with quote
The standard NMEA refresh cycle is 1 second (1000 milliseconds).
Every second the receiver gets a fix, sends the required NMEA sequences and then waits for the next second
In normal mode the receiver stays switched on for the whole cycle.
In Trickle Mode (low power) the receiver can be put to sleep after it finished all its business. This is where you specify the On Time. I found that a value as low as 200 ms is sufficient for it to keep its position, with only a slight degradation in signal. Don't try to go below that.
The battery life will not expand linearly, but you can expect up to 30% more in 200 ms trickle mode. I had the Emtac running for 8 straight hours, where it normally would last only 5 to 6 hours.
Lutz
TomTom/TeleAtlas NAVTEQ
wjrs5
PostPosted: Sat Jul 17, 2004 4:24 pm    Post subject: Walking Settings Reply with quote
So for maximum battery time when out walking, the best settings would be:
Update rate (sec) 2
On time (ms) 200
Or would it be best to have the update rate set at 1?
Brandon
PostPosted: Wed Jul 21, 2004 5:15 am    Post subject: Reply with quote
It depends on your use for walking. If you wanted to trace your position, I would probably suggest the trickle power mode. However if you wanted to check your position about once every 15 or 30 minutes I would probably suggest turning the reciever off until you want to check your next location.
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
sjs
PostPosted: Sat Aug 21, 2004 6:30 pm    Post subject: Reply with quote
so we lower the on time to 200ms....but what is a good number for the update time? would it still work if i told it to update every 15 or 30 seconds or even a minute? that would be good enough for me if i was walking...
lbendlin
PostPosted: Sat Aug 21, 2004 7:40 pm    Post subject: Reply with quote
very good question. I haven't tried that yet. But from what I understand the farther away the wake periods are the more time the circuits will need to lock onto the sats.
So if you would leave it at 200 ms On-time and set the interval to 15 seconds the receiver might not be able to maintain the fix. I say "might" because I haven't tested that yet. Somebody with lots of time and a scientific background could actually produce a X/Y chart with the x axis being the on-time and the Y-axis being the interval, and then determine the filed of success versus the field of failure...
Lutz
sjs
PostPosted: Tue Aug 24, 2004 10:40 pm    Post subject: Reply with quote
yes, neat idea...if i ever get a trine...
is this feature precisely what is known as "trickle" in the first place?
lbendlin
PostPosted: Tue Aug 24, 2004 11:16 pm    Post subject: Reply with quote
yes. trickle in itself means that full power is not always supplied to the device. There are periods of full power interchanging with sleep mode power.
But as far as I know so far trickle has always assumed that a full cycle would take just one second - and nobody is really sure what happens when you go beyond that.
Lutz
sjs
PostPosted: Wed Aug 25, 2004 6:27 pm    Post subject: Reply with quote
ok thanks...now is trickle part of the spec of Sirf or optional? are there freeware utilities to tweak the trickle or must you use an OEM supplied app of some kind?
lbendlin
PostPosted: Wed Aug 25, 2004 9:58 pm    Post subject: Reply with quote
I think it is part of some SiRF chipsets. I normally use Crux_View to set this mode, but haven't been successful to do so with all the SiRF based devices I tested. You don't break anything by trying, though.
Lutz
sjs
PostPosted: Thu Sep 02, 2004 2:12 am    Post subject: Reply with quote
great, thanks :-)
hogbreath
PostPosted: Sun Aug 07, 2005 3:46 pm    Post subject: Reply with quote
[b]lbendlin
I Get 8hrs normal run time, so would expect you to be 10hrs on trickle?
How do I check to see what mode is in use, is this via Crux_View only?
Pete
Thanks in advance
