Pocket GPS World :: View topic - slow warning of speed cameras
ducati748
PostPosted: Thu Aug 04, 2005 7:12 pm    Post subject: slow warning of speed cameras Reply with quote
hi, im running tt5 on a mio 168, and im using the pocket gps camera database to detect camera,s.
i have it set to warn me of the camera,s by a bleep and then on screen it tells me what sort it is, and how far away it is, but then as i get closer to the camera the distance on screen seems to be lagging behind by about 75-100 yards, sometimes after ive pasted the camera by 100 yards its still saying 70 yards to go, is this normal?? + if i have the poi highlighted on the route im taking the screen seems to skip along instead of running smooth can anyone shed some light on this??
when i downloaded the camera database via poiedit i highlighted all the camera files, do i need them all?? and could they be causing the trouble??.
julianbarker
PostPosted: Thu Aug 04, 2005 8:43 pm    Post subject: Reply with quote
You have discovered the POI display bug in TT5. If you select "Hide POI" TT5 will draw the screen correctly, but only show you the POI it is warning you about.
The bug is a major irritation for me - TT4 was much better in this respect and could display well over 12,000 POIs on a slow IPAQ without problems.
esim
PostPosted: Thu Aug 04, 2005 8:46 pm    Post subject: Reply with quote
Yes I have found the same - if I have more than ~4 POI's active then the refresh rate becomes very low.
However if you set warnings for POI then they'll show up on the map when you get the warning. I've set speed cameras to pop up at 200-500 yds and only on route and it seems to work well.
esim
TT 720, TT One v3
HTC One V, Asus TF101, Garmin eTrex
ducati748
PostPosted: Thu Aug 04, 2005 9:04 pm    Post subject: Reply with quote
thanks for the quick replys, hidden the poi and that seems to have helped the screen to run much smoother, so ill just have to live with the inaccriate distance readings then or is there anything else i could try???
andy-c1
PostPosted: Thu Aug 04, 2005 9:29 pm    Post subject: Reply with quote
you will find if you remove any tt3 poi's you should be ok with camera database .
what i did was removed all the pictures and swopped them for poi icons on tt5 ,ok it's not the best but at lest you get to see the camera's all the time
TomTom 5001
Bazzer
PostPosted: Fri Aug 05, 2005 11:22 am    Post subject: Reply with quote
I'm also running TT5 ver 5.1 on my Mio 168 with the PGPSWorld camera database, with hidden POI's, I get safety camera warnings 250-500 mtrs beforehand depending on the speed of the road.
However, there is quite a lag between what is on the map and where I am on the ground. For example, I had passed a redlight camera, but the display was still counting down from 70 yards ??
Is this a bug in the system, or is it the refresh rate of the map ?
Hopefully this will be addressed in the next update.
Baz
Garmin DriveSmart 61 LMT-D
TomTom Go 50 - Going in the BIN
TomTom Go 730 (RIP)
Garmin Montana 650
Garmin Oregon 45oT
Garmin Edge 1000
Tracklogs Digital Mapping
howardr
PostPosted: Fri Aug 05, 2005 5:36 pm    Post subject: Reply with quote
Judging by your user name I expect Tom Tom is having difficulty keeping up! :D
Howard
Google Maps on Samsung Galaxy S2
23.054 (28 May 25)
