Pocket GPS World :: View topic - syson gps cf plus with tommtom 5
bigal2003
PostPosted: Thu Jul 14, 2005 9:21 am    Post subject: syson gps cf plus with tommtom 5 Reply with quote
hi al
i need your help, i,ve just upgraded to tomtom 5 which at the moment looks good but i have a problem, its says all the time no gps device. i,ve tried to change it to all of the different devices listed but it dos'nt seem to cover my gps receiver......can you help i need it to work this weekend!!!
cisco43
PostPosted: Fri Jul 15, 2005 2:37 am    Post subject: Reply with quote
Sad
I'm in the same boat.
Any one managed to get it working???
Darien
PostPosted: Thu Jul 21, 2005 11:37 pm    Post subject: Reply with quote
Here is the answer you need, it seems mad but only way to get to work.
Select "Change preferences"
Select Preferences 4 of 6
Tap "Show GPS Status"
Tap "Configure"
Here is the odd part
Select "Other Cable NMEA GPS"
GPS baud rate = 4800
Done
Now select your Bluetooth Serial Port.
Good luck and happy nav'ing
Darien
countyboy239
PostPosted: Fri Jul 22, 2005 9:19 am    Post subject: Reply with quote
I have tried that and doesnt seem to work for me,,,It seems logical to click on syson chip,,,Syson chip is picking up satellites but tom tom saying "no gps device"...Can anyone help, I have tried lots of combinations,,,,!! Crying or Very sad
frolicuk
PostPosted: Sat Jul 30, 2005 3:13 pm    Post subject: similar problem Reply with quote
I also cannot seem to get the dam thing to link up.
My combination is
HP HX 4700
Sysonchip GPS CF Plus
Navigator 5
countyboy239
PostPosted: Sat Jul 30, 2005 6:41 pm    Post subject: Reply with quote
http://www.tomtom.com/support/rightnow.php?Page=http://62.250.17.58/cgi-bin/uk.cfg/php/enduser/std_adp.php?p_faqid=3361
Try the above patch..it worked for me..
frolicuk
PostPosted: Sun Jul 31, 2005 7:15 pm    Post subject: Reply with quote
tried the patch and variations on setting the syson cf card up on different com ports no luck.
Update from TT is installed.
any more ideas.
SjB
PostPosted: Wed Aug 10, 2005 8:28 pm    Post subject: Reply with quote
I use a SysOnChip CF 256 antenna with my iPAQ 2210. I have recently upgraded from TT3 to TT5 and having used the 'other NMEA' and 4800 baud settings during the upgrade have had no problems.
"No GPS device' appears on first starting TT5 (even though the SysOnChip is clearly showing a fix with a solid, non-flashing, LED but disappears after ten seconds or so.
Feel free to ask me to check anything else such as precise version numbers of anything if you wish.
kjnpbr
PostPosted: Wed Aug 10, 2005 11:18 pm    Post subject: Reply with quote
I've had absolutely no problems with my SysonChip CFPlus. What I think your problem might be is that your GPS device may be in SIRF mode, I don't think Nav5 is SIRF compatible. If you have your SysonChip driver disc, it has instructions in powerpoint format on how to change from SIRF to NMEA. Then you can use the method above to set your tomtom up.
