dancie Occasional Visitor
Posted: Fri Jul 29, 2005 4:17 pm Post subject: replacing boings and bells with voices |
I have downloaded the PPS version 5 voice file and imported it to the PDA, I renamed the data05.chk file as data05old.chk and renamed the new file as data05.chk. I still get the original sounds when I test the POIs, what am I doing wrong please?
Dell Axim X5
TomTom Navigator 5 |
Oldboy Pocket GPS Moderator
Posted: Fri Jul 29, 2005 7:00 pm Post subject: |
You changed the wrong file. Data05.chk is Janes voice.
You need to rename DATA.CHK to DATAOLD.CHK then rename the file you copied, to Data.chk and then finally rename data05old.chk to data05.chk. _________________ Richard
Posted: Fri Jul 29, 2005 11:27 pm Post subject: |
On my machine the file lives in /program files/navigator. No wonder I couldn't get it to work! All fixed now, thanks for the clear advice. |
Posted: Sat Jul 30, 2005 12:47 pm Post subject: |
One final point, is it necessary to have the "pocketgps_uk_sc " files if all the others are in place, I ask because they seem to confuse things. I would think that they are a total list with no distinction between them whereas the individual ones are specific in their purpose.
Thanks in advance |
Posted: Sat Jul 30, 2005 5:51 pm Post subject: |
dancie wrote: | One final point, is it necessary to have the "pocketgps_uk_sc " files if all the others are in place, I ask because they seem to confuse things. I would think that they are a total list with no distinction between them whereas the individual ones are specific in their purpose.
Thanks in advance |
There can be 3 setups for speed cameras.
The first is a single file that contains all the cameras together, without any reference to what type. This is named pocketgps_uk_sc.ov2 and found in the 'single file version' folder.
Second is the 5 file version that divides the cameras into types. Gatso, Mobile, Specs, Redlight and Temporary. These you will find in the 'ov2 bmp' files.
Third is the full 17 file version that divides the Gatso and Mobile files into speed zones. There are 7 each of the Gatso and Mobile files. These are found in the 'speed zoned/gatso/ov2 bmp' and speed zoned/mobile/ov2 bmp' folders. Add to these the Specs, Redlight and Temporary files as above.
I have not included the Continental file because you will only need this if going to the continent.. But should you want it , it's in the 'ov2 bmp' folder. _________________ Richard
