Pocket GPS World :: View topic - TTN5 No keyboard
TTN5 No keyboard
Blum
PostPosted: Sat Jul 30, 2005 9:20 am    Post subject: TTN5 No keyboard Reply with quote
I have installed TTN5 on my Imate PDA2k. I have searched this forum but cannot find anyone that has had this problem.
In Navigator or Map view I fail to get a keyboard to tap, fortunately the pda2k has a slide out physical key board. I have e mailed Tomtom with no reply after 3 days, any ideas guys????
TIA.
PostPosted: Sat Jul 30, 2005 9:26 am    Post subject: Reply with quote
Get the up-grade to vs 5,1 this is a well known problem and affects the XDAIIs (which is the same device), try a search on XDA and you will find loads of info - Mike
BV
PostPosted: Sat Jul 30, 2005 10:39 am    Post subject: Incoming Calls etc... Reply with quote
Mike, I also have an XDA IIs it works great with the Tom Tom Nav 5.1.
When I first start out I can make or take phone calls without it affecting the navigation, but it seems that after around 30 minutes into my navigation if I try to make an outgoing call or accept an incoming call it locks up and has to be soft rest. Any ideas?
BV.
PostPosted: Sat Jul 30, 2005 10:44 am    Post subject: Reply with quote
What type of GPS unit are you using BT or wired, second do you use a BT headset with it, thirdly is it an O2 unit, I have used mine for long distance trips with the sat nav running and making / receiving calls no problems (in the end, in the beginning it was a nightmare and nearly went flying on a couple of occasions), let me know the answers to above I might be able to offer more specific help - Mike
BV
PostPosted: Sat Jul 30, 2005 1:16 pm    Post subject: Reply with quote
Thanks for the reply Mike. It is an O2 unit I have had since it first came out, I have also downloaded the latest system software.
I use the bluetooth TOM TOM mark II gps receiver. My bluetooth headset is the bluetrek.
As I say for the first 30 minutes I can make and receive calls, but after that if I touch a hardware button or receive an incoming call it freezes.
Otherwise it works great with traffic also.
BV.
PostPosted: Sat Jul 30, 2005 1:50 pm    Post subject: Reply with quote
Unfortunatly what I am going to tell you to do involves a hard reset :
1/ back-up all contacts and appoitments to the onboard storrage or an SD card. There is no point in backing up the software as this will only make maters worse.
2/ Hard reset the device, and sit with it while it restarts, towards the end you get prompted for install personel or corporate - select corporate and input code 0506.
3/ re-install all your contacts / appoitments etc (but NO programs from any back-up)
4/ Re-install your programs as if it were a new device
The above turned my XDAIIs from a useles bit of kit to something I can now use, all it does is gets rid of all the O2 active interface that they (O2) put on the phone, which makes the PDA unstable - so get shut of the bad software. Note if you re-install the applications from a back-up you will put this rubish back on the phone, and it will make the device even worse - believe me - I am talking from experiance, I tried it.
On a final note if you get no sound from the speaker when answering or making a call - turn the bluetooth on then off and try again, a tad annoying but until HTC get the BT drivers sorted out we will all have to live with this.
Hope the above is of use - Moderators if you want to split this thread and put the XDA stuff where it should be please feel free - Mike
BV
PostPosted: Sun Jul 31, 2005 11:41 pm    Post subject: Reply with quote
Mike you are an absolute genius. Following your advice to the letter, my XDAIIs is now like a new machine. Fantastic.
Best regards, BV
PostPosted: Mon Aug 01, 2005 7:59 am    Post subject: Reply with quote
BV, glad it all worked, just one question does your BT GPS work OK when making a call using the BT heaset at the same time i.e. when driving, mine is fine until I terminate the call using the headset and at that point it terminates the GPS - no nav - real annoying when driving - in the end I went for a wired GPS to overcome the problem - just wondering have you ever seen the same behavious? - Mike
BV
PostPosted: Mon Aug 01, 2005 10:22 am    Post subject: Reply with quote
Hi Mike, the TOM TOM GPS bluetooth receiver has been very good and has not been affected by my bluetooth headset. Sorry I cannot help.
BV.
