chris_w Pocket GPS Verifier
Joined: Nov 09, 2004 Posts: 628 Location: West Yorkshire
Posted: Thu Jul 28, 2005 11:22 am Post subject: |
I have a BIG problem with the way Navigon have handled this
Anyway that won't get your problem solved.
First of all TMC for V4 is still working - checked today.
A few questions :-
1. Is the ariel damaged? if the TMC module is recognised and cycling through the stations it might just be the ariel. Is there any chance of trying a different Ariel?
2. Have you tried changing the GPS type in settings? I've had a similar problem - if you go into your GPS settings change it from "Navigon Modular" to "Navigon with TMC" or vice versa (make sure you save changes) and this may bring your TMC back - it's worked for me on a few occasions.
Hope this helps _________________ Thanks,
Chris |
Peppercorn Occasional Visitor
Posted: Sun Jul 31, 2005 9:52 pm Post subject: MN4 and TMC |
Again, many thanks for your reply. The antenna seems to be OK; I checked the resistance with an ohmmeter. The main setting right now says "Navigon with TMC". I will change that and see how it works. |
Posted: Mon Aug 01, 2005 12:21 pm Post subject: |
OK - I'd be interested to know if it works.............. _________________ Thanks,
Chris |
Posted: Tue Aug 02, 2005 9:45 pm Post subject: MN4 and TMC |
Chris,
I've just finished an extensive testing session. I have plugged the TMC receiver in and out, and tried all permutations of Navigon Modular and Navigon with TMC in the Settings menu, all with the same result: The TMC panel stays orange and the receiver seems to be cycling without hitting a valid station. I probably have a hardware failure and will contact Navigon to get that sorted. |
Posted: Tue Aug 02, 2005 11:43 pm Post subject: |
Sounds like it if non of that works - hope you get it fixed _________________ Thanks,
Chris |
ksistrunk Occasional Visitor
Posted: Mon Aug 22, 2005 2:31 pm Post subject: Does Navigon MN5 TMC work in germany? |
I need to know if Navigon MN5 1st of all has TMC, and secondly does it work in germany.
Please help. Thanks!!!! |
Posted: Mon Aug 22, 2005 2:42 pm Post subject: |
Navigon 5 does have TMC and it does work in Germany.
Check out www.navigon.com - this will give you more information
Hope this helps. _________________ Thanks,
Chris |
Posted: Mon Aug 22, 2005 2:46 pm Post subject: |
wow that was a fast response. thanks. so i will get it then. I just got a gns 5840 gps/ rds /tmc receiver.
i hope it works good.
well see |
Posted: Mon Aug 22, 2005 4:36 pm Post subject: |
You didn't mention you had your own hardware
You'll need the Navigon TMC Receiver for it to work with Navigon.
I don't believe that Navigon TMC will work with anything other than it's own hardware.
Best to check with them before you buy. _________________ Thanks,
Chris |
Posted: Mon Aug 22, 2005 11:14 pm Post subject: thats not what the manufactuer said |
They said it works fine with navigon
it is the GNS 5840 receiver |
Posted: Mon Aug 22, 2005 11:20 pm Post subject: |
Go for it! - Glad it works  _________________ Thanks,
Chris |
